System Administration Guide: Basic Administration
Specifying Different Densities for a Tape Drive
By default, the drive writes at its “preferred” density, which is usually the highest density the tape drive supports. If you do not specify a tape device, the command writes to drive number 0 at the default density the device supports.
To transport a tape to a system whose tape drive supports only a certain density, specify a device name that writes at the desired density. The following table describes how to specify different densities for a tape drive.
Table 52–4 Specifying Different Densities for a Tape Drive
Drive, Density, and Rewind Value
Use this Option
First drive, low density, rewind
/dev/rmt/0l
First drive, low density, no rewind
/dev/rmt/0ln
Second drive, medium density, rewind
/dev/rmt/1m
Second drive, medium density, no rewind
/dev/rmt/1mn
The unit and density characters are shown in Backup Device Names.
