Use the following table to locate information on managing disks with EFI disk labels.
Task |
For More Information |
If the system is already installed, connect the disk to the system and perform a reconfiguration boot. | |
Repartition the disk with the format utility, if necessary. | |
Create disk volumes, and if needed, create soft partitions with Solaris Volume Manager. |
“Storage Management Concepts” in Solaris Volume Manager Administration Guide |
Create UFS file systems for the new disk with the newfs command if the file systems are less than 1 terabyte. | |
Or, create a QFS file system. |
