On x86 based systems, disks are divided into fdisk partitions. An fdisk partition is a section of the disk that reserved for a particular operating environment, such as the Solaris release.
The Solaris release places ten slices, numbered 0–9, on a Solaris fdisk partition as shown in the following table.
Table 32–3 x86: Customary Disk Slices
Slice |
File System |
Usually Found on Client or Server Systems? |
Purpose |
0 |
root (/) |
Both |
Holds the files and directories that make up the operating system. |
1 |
swap |
Both |
Provides virtual memory, or swap space. |
2 |
Both |
Refers to the entire disk, by convention. The size of this slice should not be changed. |
3 |
/export |
Both |
Optional slice to be defined based on your site's needs. Can be used on a server to hold alternative versions of operating systems that are required by client systems. |
4 |
Optional slice to be defined based on your site's needs. |
5 |
Both |
Optional slice to be defined based on your site's needs. Can be used to hold application software added to a system. If a slice is not allocated for the /opt file system during installation, the /opt directory is put in slice 0. |
6 |
/usr |
Both |
Holds operating system commands (also known as executables). This slice also holds documentation, system programs (init and syslogd, for example) and library routines. |
7 |
/home or /export/home |
Both |
Holds files that are created by users. |
8 |
Both |
Contains information necessary for to boot the Solaris environment from the hard disk. The slice resides at the beginning of the Solaris fdisk partition (although the slice number itself does not indicate this fact), and is known as the boot slice. |
9 |
Both |
Provides an area that is reserved for alternate disk blocks. Slice 9 is known as the alternate sector slice. |
