$ cachefslog -f log-file-path /mount-point |
-f |
Sets up logging. |
log-file-path |
Specifies the location of the log file. The log file is a standard file you create with an editor, such as vi. |
/mount-point |
Designates the mount point (CacheFS file system) for which statistics are being collected. |
Verify that you correctly set up the log file.
$ cachefslog /mount-point |
The following example shows how to set up the /var/tmp/samlog log file to collect statistics about the /home/sam directory.
$ cachefslog -f /var/tmp/samlog /home/sam /var/tmp/samlog: /home/sam |
