System Administration Guide: Basic Administration
Example—Displaying Packed Files Information
The following example shows that the doc_file file is successfully packed.
$ cachefspack -i doc_file
cachefspack: file doc_file marked packed YES, packed YES
In the following example, the /data/abc directory contains the bin subdirectory. The bin subdirectory has three files: big, medium, and small. Although the big and small files are specified to be packed, they are not. The medium file is successfully packed.
$ cd /data/abc
$ cachefspack -i bin
cachefspack: file /bin/big marked packed YES, packed NO
cachefspack: file /bin/medium marked packed YES,
packed YES
cachefspack: file /bin/small marked packed YES,
packed NO
If you use the -iv options together, you get additional information as to whether the file or directory specified has been flushed from the cache. For example:
$ cd /data/bin
$ cachefspack -iv bin
cachefspack: file /bin/big marked packed YES, packed NO,
nocache YES
packed YES, nocache NO
packed NO
nocache NO
The last line of the preceding example shows that the directory contents have not been flushed from the cache.
