System Administration Guide: Basic Administration
Example—Mounting a UFS File System With Logging Enabled (mount Command)
UFS logging eliminates file system inconsistency, which can significantly reduce the time of system reboots. The following example shows how to mount /dev/dsk/c0t3d0s7 on the /files1 directory with logging enabled.
# mount -o logging /dev/dsk/c0t3d0s7 /files1
