System Administration Guide: Basic Administration
How to Determine a File System's Type
This procedure works whether the file system is mounted or not.
Determine a file system's type by using the grep command.
$ grep mount-point fs-table
mount-point
Specifies the mount point name of the file system for which you want to know the file system type. For example, the /var directory.
fs-table
Specifies the absolute path to the file system table in which to search for the file system's type. If the file system is mounted, fs-table should be /etc/mnttab. If the file system isn't mounted, fs-table should be /etc/vfstab.
Information for the mount point is displayed.
Note –
If you have the raw device name of a disk slice, you can use the fstyp command to determine a file system's type (if the disk slice contains a file system). For more information, see fstyp(1M).
Examples—Determining a File System's Type
The following example uses the /etc/vfstab file to determine the type of the /export file system.
$ grep /export /etc/vfstab
/dev/dsk/c0t3d0s6   /dev/rdsk/c0t3d0s6  /export ufs   2       yes    -
The following example uses the /etc/mnttab file to determine the file system type of the currently mounted diskette (which was mounted by vold).
$ grep /floppy /etc/mnttab
/vol/dev/diskette0/unnamed_floppy   /floppy/unnamed_floppy  pcfs rw,
nohidden,nofoldcase,dev=16c0009      89103376
