System Administration Guide: Basic Administration
The Mounted File System Table
Whenever you mount or unmount a file system, the /etc/mnttab (mount table) file is modified with the list of currently mounted file systems. You can display the contents of this file with the cat or more commands, but you cannot edit it. Here is an example of an /etc/mnttab file:
$ more /etc/mnttab
/dev/dsk/c0t0d0s0  /  ufs rw,intr,largefiles,onerror=panic,suid,dev=2200000 938557523
/proc   /proc   proc    dev=3180000     938557522
fd      /dev/fd fd      rw,suid,dev=3240000     938557524
mnttab  /etc/mnttab     mntfs   dev=3340000     938557526
swap    /var/run        tmpfs   dev=1   938557526
swap    /tmp    tmpfs   dev=2   938557529
/dev/dsk/c0t0d0s7 /export/home ufs rw,intr,largefiles,onerror=panic,suid,dev=2200007 ...
