System Administration Guide: Basic Administration
Example—Adding an Unsigned Solaris Patch
In the following example, the Solaris 8 patch, 111879–01, is added to the system. The patch had already been downloaded to the system previously.
# patchadd /export/Sol8patch/111879-01
Checking installed patches...
Verifying sufficient filesystem capacity (dry run method)...
Installing patch packages...
Patch number 111879-01 has been successfully installed.
See /var/sadm/patch/111879-01/log for details
Patch packages installed:
  SUNWwsr
# patchadd -p | grep 111879-01
Patch: 111879-01 Obsoletes:  Requires:  Incompatibles:  Packages: SUNWwsr
