System Administration Guide: Basic Administration
Fields in the group File
The fields in the group file are separated by colons and contain the following information:
group-name:group-password:gid:user-list
For example:
bin::2:root,bin,daemon
The following table describes the group file fields.
Table 4–14 Fields in the group File
Field Name
Description
group-name
Contains the name assigned to the group. For example, members of the chemistry department in a university might be called chem. Group names can have a maximum of eight characters.
group-password
Usually contains an asterisk or is empty. The group-password field is a relic of earlier versions of UNIX. If a group has a password, the newgrp command prompts users to enter the password. However, no utility exists to set the password.
gid
Contains the group's GID number. It must be unique on the local system, and should be unique across the entire organization. Each GID number must be a whole number between 0 and 60002. Numbers under 100 are reserved for system default group accounts. User defined groups can range from 100 to 60000. 60001 and 60002 are reserved and assigned to nobody and noaccess, respectively.
user-list
Contains a comma-separated list of user names, representing the user's secondary group memberships. Each user can belong to a maximum of 15 secondary groups.
Default group file
The default Solaris group file contains the following system groups that support some system-wide task, such as printing, network administration, and electronic mail. Many of these groups having corresponding entries in the passwd file.
root::0:root
other::1:
sys::3:root,bin,sys,adm
adm::4:root,adm,daemon
uucp::5:root,uucp
mail::6:root
tty::7:root,adm
lp::8:root,lp,adm
nuucp::9:root,nuucp
staff::10:
daemon::12:root,daemon
smmsp::25:smmsp
sysadmin::14:root
nobody::60001:
noaccess::60002:
nogroup::65534:
Table 4–15 Default group File Entries
Group Name
Group ID
Description
root
0
Superuser group.
other
1
Optional group.
bin
2
Administrative group associated with running system binaries.
sys
3
Administrative group associated with system logging or temporary directories.
adm
4
Administrative group associated with system logging.
uucp
5
Group associated with uucp functions.
mail
6
Electronic mail group.
tty
7
Group associated with tty devices.
lp
8
Line printer group.
nuucp
9
staff
10
General administrative group.
daemon
12
Group associated with routine system tasks.
sysadmin
14
Administrative group associated with Admintool and Solstice AdminSuite tools.
smmsp
25
Sendmail message submission program daemon.
nobody
60001
Group assigned to users or software processes that do not need nor should have any special permissions.
noaccess
60002
Group assigned to a user or a process that needs access to a system through some application but without actually logging in.
nogroup
65534
Group assigned to a user who not a member of a known group.
