System Administration Guide: Resource Management and Network Services
SLP Status Codes
Table 20–1 SLP Status Codes
Status Type
Status Code
Description
No Error
Request was processed without error.
LANGUAGE_NOT_SUPPORTED
For an AttrRqst or SrvRqst, there is data for the service type in the scope, but not in the language that is indicated.
PARSE_ERROR
The message fails to follow SLP syntax.
INVALID_REGISTRATION
The SrvReg has problems. For example, a zero lifetime or an omitted language tag.
SCOPE_NOT_SUPPORTED
The SLP message did not include a scope in its scope list that is supported by the SA or DA that answered the request.
AUTHENTICATION_UNKNOWN
The DA or SA received a request for an unsupported SLP SPI.
AUTHENTICATION_ABSENT
The UA or DA expected URL and attribute authentication in the SrvReg and did not receive it.
AUTHENTICATION_FAILED
The UA or DA detected an authentication error in an Authentication block.
VER_NOT_SUPPORTED
Unsupported version number in message.
INTERNAL_ERROR
10
An unknown error occurred in the DA or SA. For example, the operating system had no remaining file space.
DA_BUSY_NOW
11
The UA or SA should retry, using exponential backoff. The DA is busy processing other messages.
OPTION_NOT_UNDERSTOOD
12
The DA or SA received an unknown option from the mandatory range.
INVALID_UPDATE
13
The DA received a SrvReg without FRESH set, for an unregistered service or with inconsistent service types.
MSG_NOT_SUPPORTED
14
The SA received an AttrRqst or SrvTypeRqst and does not support it.
REFRESH_REJECTED
15
The SA sent a SrvReg or partial SrvDereg to a DA more frequently than the DA's min-refresh-interval.
