This section, which includes the following topics, describes some of the differences in the Solaris version of sendmail as compared to the generic Berkeley version.
The following tables list the flags that are used when compiling the version of sendmail that is delivered with the Solaris 9 release. If your configuration requires other flags, you need to download the source and recompile the binary. You can find information about this process at http://www.sendmail.org.
Table 23–1 General sendmail Flags
Flag |
Description |
SOLARIS=20900 |
Support for the Solaris 9 operating environment. |
MILTER |
Support for the Mail Filter API. |
NETINET6 |
Support for IPv6. This flag has been moved from conf.h to Makefile. |
Table 23–2 Maps and Database Types
Flag |
Description |
NDBM |
Support for ndbm databases |
NEWDB |
Support for db databases |
USERDB |
Support for the User database |
NIS |
Support for nis databases |
NISPLUS |
Support for nisplus databases |
LDAPMAP |
Support for LDAP maps |
MAP_REGEX |
Support for regular expression maps |
Table 23–3 Solaris Flags
Flag |
Description |
SUN_EXTENSIONS |
Support for Sun extensions that are included in sun_compat.o. |
SUN_LOOKUP_MACRO |
Support for the L and G configuration commands in sendmail.cf. Use of these commands is not recommended. |
SUN_INIT_DOMAIN |
For backward compatibility, support for the use of NIS domain names to fully qualify the local host name. For more information, look for vendor-specific information in http://www.sendmail.org. |
SUN_SIMPLIFIED_LDAP |
Support for a simplified LDAP API, which is specific to Sun. For more information, look for vendor-specific information in http://www.sendmail.org. |
VENDOR_DEFAULT=VENDOR_SUN |
Selects Sun as the default vendor. |
The following table lists generic flags that are not used to compile the version of sendmail that is delivered with the Solaris 9 release.
Table 23–4 Generic Flags Not Used in the Solaris Version of sendmail
Flag |
Description |
SASL |
Simple Authentication and Security Layer (RFC 2554) |
STARTTLS |
Transaction Level Security (RFC 2487) |
To see a list of the flags that are used to compile sendmail, use the following command.
% /usr/lib/sendmail -bt -d0.10 < /dev/null |
The preceding command does not list the flags that are specific to Sun.
The Solaris release does not include all of the command synonyms that are provided in the generic release from Berkeley. This table includes a complete list of the command aliases. The table also lists whether the commands are included in the Solaris release and how to generate the same behavior by using sendmail.
Table 23–5 Alternate sendmail Commands
Alternate Name |
In the Solaris Release? |
Options With sendmail |
hoststat | No | sendmail -bh |
mailq | Yes | sendmail -bp |
newaliases | Yes | sendmail -bi |
purgestat | No | sendmail -bH |
smtpd | No | sendmail -bd |
The Solaris 9 version of sendmail includes a configuration option that enables you to define the version of the sendmail.cf file. This option enables older configuration files to be used with the current version of sendmail. You can set the version level to values between 0 and 10. You can also define the vendor. Either Berkeley or Sun is a valid vendor option. If a version level is specified but no vendor is defined, Sun is used as the default vendor setting. The following table lists some of the valid options.
Table 23–6 Version Values for the Configuration File
Field |
Description |
V7/Sun |
Setting that was used for version 8.8 of sendmail. |
V8/Sun |
Setting that was used for version 8.9 of sendmail. This setting was included in the Solaris 8 release. |
V9/Sun |
Setting that was used for versions 8.10 and 8.11 of sendmail. |
V10/Sun |
Setting that is used for version 8.12 of sendmail. Version 8.12 is the default for the Solaris 9 release. |
You are urged not to use V1/Sun. For more information, refer to http://www.sendmail.org/vendor/sun/differences.html#4.
For task information, refer to Building the sendmail.cf Configuration File (Task) in Chapter 22, Mail Services (Tasks).
