The following table describes the procedures that are needed to use NCA.
Task |
Description |
For Instructions |
Planning for NCA |
A list of issues to be resolved before you enable the use of NCA. | |
Enabling NCA |
Steps to enable in-kernel caching of web pages on a web server. | |
Disabling NCA |
Steps to disable in-kernel caching of web pages on a web server. | |
Administering NCA logging |
Steps to enable or disable the NCA logging process. | |
Loading the NCA socket library |
Steps to use NCA if the AF_NCA socket is not supported. |
