System Administration Guide: Resource Management and Network Services
Administering the Caching of Web Pages (Tasks)
The following sections cover the procedures to enable or disable parts of the service.
How to Enable Caching of Web Pages
  1. Become superuser.
  2. Register the interfaces.
    Type the names of each of the physical interfaces in the /etc/nca/nca.if file. See the nca.if(4) man page for more information.
    # cat /etc/nca/nca.if
    hme0
    hme1
    Each interface must have an accompanying hostname.interface-name file and an entry in /etc/hosts file for the contents of hostname.interface-name. To start the NCA feature on all interfaces, place an asterisk, *, in the nca.if file.
  3. Enable the ncakmod kernel module.
    Change the status entry in /etc/nca/ncakmod.conf to enabled.
    # cat /etc/nca/ncakmod.conf
    # NCA Kernel Module Configuration File
    status=enabled
    httpd_door_path=/var/run/nca_httpd_1.door
    nca_active=disabled
    See the ncakmod.conf(4) man page for more information.
  4. (Optional) Enable NCA logging.
    Change the status entry in /etc/nca/ncalogd.conf to enabled.
    # cat /etc/nca/ncalogd.conf
    # NCA Logging Configuration File
    status=enabled
    logd_path_name="/var/nca/log"
    logd_file_size=1000000
    You can change the location of the log file by changing the path that is indicated by the logd_path_name entry. The log file can be a raw device or a file. See the following examples for samples of NCA log file paths. See the ncalogd.conf(4) man page for more information about the configuration file.
  5. (Optional) Define ports for multiple instance support.
    Add the port numbers in the /etc/nca/ncaport.conf file. This entry causes NCA to monitor port 80 on all configured IP addresses.
    # cat /etc/nca/ncaport.conf
    # NCA Kernel Module Port Configuration File
    ncaport=*/80
  6. For IA only: Increase the virtual memory size.
    Use the eeprom command to set the kernelbase of the system.
    # eeprom kernelbase=0x90000000
    # eeprom kernelbase
    The second command verifies that the parameter has been set.
    Note –
    By setting the kernelbase, you reduce the amount of virtual memory that user processes can use to less than 3 Gbytes. This restriction means that the system is not ABI compliant. When the system boots, the console displays a message that warns you about noncompliance. Most programs do not actually need the full 3–Gbyte virtual address space. If you have a program that needs more than 3 Gbytes, you need to run the program on a system that does not have NCA enabled.
  7. Reboot the server.
Example–Using a Raw Device as the NCA Log File
The logd_path_name string in ncalogd.conf can define a raw device as the place to store the NCA log file. The advantage to using a raw device is that the service can run faster because the overhead in accessing a raw device is less.
The NCA service tests any raw device that is listed in the file to ensure that no file system is in place. This test ensures that no active file systems are accidentally written over.
To prevent this test from finding a file system, run the following command. This command destroys part of the file system on any disk partition that had been configured as a file system. In this example, /dev/rdsk/c0t0d0s7 is the raw device that has an old file system in place.
# dd if=/dev/zero of=/dev/rdsk/c0t0d0s7 bs=1024 count=1
After running dd, you can then add the raw device to the ncalogd.conf file.
status=enabled
logd_path_name="/dev/rdsk/c0t0d0s7"
Example–Using Multiple Files for NCA Logging
The logd_path_name string in ncalogd.conf can define multiple targets as the place to store the NCA log file. The second file is used when the first file is full. The following example shows how to select to write to the /var/nca/log file first and then use a raw partition.
status=enabled
logd_path_name="/var/nca/log /dev/rdsk/c0t0d0s7"
How to Disable Caching of Web Pages
  2. Disable the ncakmod kernel module.
    Change the status entry in /etc/nca/ncakmod.conf to disabled.
    status=disabled
    nca_active=disabled
  3. Disable NCA logging.
    Change the status entry in /etc/nca/ncalogd.conf to disabled.
    status=disabled
    See the ncalogd.conf(4) man page for more information.
  4. Reboot the server.
How to Enable or Disable NCA Logging
NCA logging can be turned on or turned off, as needed, after NCA has been enabled. See How to Enable Caching of Web Pages for more information.
  2. Change NCA logging.
    To permanently disable logging, you need to change the status in /etc/nca/ncalogd.conf to disabled and reboot the system. See the ncalogd.conf(4) man page for more information.
    1. Stop logging.
      # /etc/init.d/ncalogd stop
    2. Start logging.
      # /etc/init.d/ncalogd start
How to Load the Socket Utility Library for NCA
Follow this process only if your web server does not provide native support of the AF_NCA socket.
In the startup script for the web server, add a line that causes the library to be preloaded. The line should resemble the following:
LD_PRELOAD=/usr/lib/ncad_addr.so /usr/bin/httpd
How to Add a New Port to the NCA Service
  2. Add a new port.
    Add a new port entry to /etc/nca/ncaport.conf. This example adds port 8888 on IP address 192.168.84.71. See ncaport.conf(4) for more information.
    ncaport=*/80
    ncaport=192.168.84.71/8888
  3. Start a new web instance.
    An address needs to be in the file that contains the NCA port configurations before a web server can use the address for NCA. If the web server is running, it must be restarted after the new address is defined.
