System Administration Guide: Resource Management and Network Services
How to Add CHAP Support to the PPP Configuration Files (Dial-in Server)
  1. Log in to the dial-in server as superuser.
  2. Modify the /etc/ppp/options file.
    Add the options that are shown in bold for CHAP support.
    # vi /etc/ppp/options
    lock
    nodefaultroute
    name CallServe
    auth
    require-chap
    name CallServe
    Defines CallServe as the CHAP name of the user on the local machine, in this instance the dial-in server
    auth
    Makes the local machine authenticate callers before establishing the link
    require-chap
    Requires peers to provide CHAP credentials before the link can be established
  3. Create the remaining PPP configuration files to support the trusted callers.
    See How to Configure Users of the Dial-in Server and How to Define Communications Over the Serial Line (Dial-in Server).
Where to Go From Here
Task
For Instructions
Configure CHAP authentication credentials for trusted callers
How to Create a CHAP Credentials Database (Dial-in Server)
