The next procedure explains how to set the modem speed for a dial-in server. For suggestions on speeds to use with Sun Microsystems' computers, see Configuring the Modem Speed.
Log in to the dial-in server.
Use the tip command to reach the modem.
Instructions for using tip to set the modem speed are in the tip(1) man page.
Configure the modem for a fixed DTE rate.
Lock the serial port to that rate, using ttymon or admintool, as discussed in “Setting Up Terminals and Modems with Serial Ports Tool” in System Administration Guide: Advanced Administration.
Task |
For Instructions |
Configure another serial port and modem on the dial-in server | |
Configure information about users that call the dial-in server |
