To provide PPP to client systems over DSL, you must first configure PPPoE on the interface that is connected to the modem or hub. Then you need to change the PPP configuration files to define the access server on the opposite end of the PPPoE.
Before you set up the PPPoE client, you must have done the following:
Installed Solaris 8 Update 6 release or subsequent releases on the client machines to use the PPPoE tunnel
Contacted the service provider for information about its PPPoE access server
Had the telephone company or service provider assemble the devices that are used by the client machines. These devices include, for example, the DSL modem and the splitter, which the telephone company rather than you might assemble.
Become superuser on the PPPoE client.
Add the name of the Ethernet interface with the DSL connection to the /etc/ppp/pppoe.if file.
For example, you add the following entry to /etc/ppp/pppoe.if for a PPPoE client that uses hme0 as the network interface that is connected to the DSL modem.
hme0 |
For more information about /etc/ppp/pppoe.if, go to /etc/ppp/pppoe.if File.
Configure the interface for PPPoE use.
# /etc/init.d/pppd start |
(Optional) Verify that the interface is now plumbed for PPPoE.
# /usr/sbin/sppptun query hme0:pppoe hme0:pppoed |
You can also use the /usr/sbin/sppptun command to manually plumb interfaces for PPPoE. For instructions, refer to /usr/sbin/sppptun Command.
You define the access server in the /etc/ppp/peers/peer-name file. Many of the options that are used for the access server are also used to define the dial-in server in a dial-up scenario. For a detailed explanation of /etc/ppp/peers.peer-name, refer to /etc/ppp/peers/peer-name File.
Define the service provider's PPPoE access server in the /etc/ppp/peers/peer-name file.
For example, the following file, /etc/ppp/peers/dslserve, defines the access server dslserve at FarISP that is introduced in Example—Configuration for a PPPoE Tunnel.
# cat /etc/ppp/peers/dslserve sppptun plugin pppoe.so connect "/usr/lib/inet/pppoec hme0" noccp noauth user Red password redsecret noipdefault defaultroute |
For a definition of the options in this file, go to /etc/ppp/peers/peer-name File for Defining an Access Server Peer.
Modify the other PPP configuration files on the PPPoE client.
Configure /etc/ppp/options as described in the instructions for configuring a dial-out machine in Configuring the Dial-out Machine.
Create an /etc/ppp/options.sppptun file. /etc/ppp/options.sppptun defines PPP options for the serial port to which the interface that is plumbed for PPPoE is attached.
You can use any options that are available for the /etc/ppp/options.ttyname file that is described in /etc/ppp/options.ttyname Configuration File. You must name the file /etc/ppp/options.sppptun because sppptun is the specified device name in the pppd configuration.
Ensure that all users can start PPP on the client.
# touch /etc/ppp/options |
Test if PPP can run over the DSL line.
# pppd debug updetach call dslserve |
dslserve is the name that is given to the access server at the ISP that is shown in Example—Configuration for a PPPoE Tunnel. The debug updetach option causes debugging information to display in a terminal window.
If PPP is running correctly, the terminal output shows the link becoming active. If PPP still does not run, try the following command to see if the servers are running correctly:
# /usr/lib/inet/pppoec -i hme0 |
Task |
For Instructions |
Configure another PPPoE client | |
Learn more about PPPoE | |
Have users of configured PPPoE clients begin running PPP over the DSL line |
Instruct the users to type pppd call ISP-server-name and then run an application or service. |
Troubleshoot PPPoE and PPP problems | |
Configure a PPPoE access server |
