pppd debug output contains Connect script failed
Your chat
script supplies a user name and ssword.
ogin: user-name
ssword: password
However, the peer that you intended to connect to does not
prompt for this information.
Delete the login and password from the chat script.
Try to call the peer again.
If you still get the message, call the ISP. Ask the ISP for
the correct login sequence.
The /usr/bin/chat -v log contains the
message: "expect (login:)" alarm read timed out
Your chat script supplies a user name and ssword.
ogin: pppuser
ssword: \q\U
However, the peer that you intend to connect to does not prompt for
this information.
pppd debug output
contains possibly looped-back
The local machine or its peer is hanging at
the command line and not running PPP. An incorrectly configured login name
and password are in the chat script.
If you still get the message, call the ISP. Ask for the correct
login sequence.
pppd debug output shows that LCP activates,
but the link terminates soon afterward.
The password in the chat script might be incorrect.
Ensure that you have the correct password for the local machine.
Check the password in the chat script. Fix the password
if incorrect.
Text from the peer begins with a tilde (~).
ogin: pppuser
ssword: \q\U
If you still get the message, call the ISP. Request the correct
login sequence.
The modem hangs.
Your chat script contains the following line to force
the local machine to wait for the CONNECT message from
the peer:
Use the following line when you want the chat script to wait for CONNECT from
the peer:
End the chat script with ~ \c.
pppd debug output contains LCP: timeout sending Config-Requests
Your chat script contains the following line to force the local machine to
wait for the CONNECT message from the peer:
the chat script to wait for CONNECT from the peer:
pppd debug output contains: Serial link is not
8-bit clean
Use the following
line when you want the chat script to wait for CONNECT from the peer:
pppd debug output contains: Loopback detected
Use the following
pppd debug output
contains SIGHUP
Use the following
