PPP links generally have three major areas of failure:
Failure of the link to be established
Poor performance of the link during regular usage
Problems that can be traced to the networks on either side of the link
This section explains how to obtain diagnostic information from pppd and its associated log files. The remaining sections in this chapter describe common problems with PPP that you can discover and fix with the aid of the PPP troubleshooting tools.
The next procedure shows how to view the current operation of a link on the local machine.
Become superuser on the local machine.
Run pppd with the serial device configured for PPP as the argument:
# pppd /dev/ttyname debug updetach |
# pppd /dev/cua/b debug updetach have route to 0.0.0.0/0.0.0.0 via 172.21.0.4 serial speed set to 230400 bps Using interface sppp0 Connect: sppp0 <--> /dev/cua/b sent [LCP ConfReq id=0x7b <asyncmap 0x0> <magic 0x73e981c8> <pcomp> <accomp>] rcvd [LCP Ident id=0x79 magic=0x0 "ppp-2.4.0b1 (Sun Microsystems, Inc., Dec 6 2000 09:36:22)"] Peer Identification: ppp-2.4.0b1 (Sun Microsystems, Inc., Dec 6 2000 09:36:22) rcvd [LCP ConfRej id=0x7b <asyncmap 0x0>] sent [LCP Ident id=0x7c magic=0x0 "ppp-2.4.0b1 (Sun Microsystems, Inc., Nov 15 2000 09:38:33)" sent [LCP ConfReq id=0x7d <magic 0x73e981c8> <pcomp> <accomp>] rcvd [LCP ConfAck id=0x7d <magic 0x73e981c8> <pcomp> <accomp>] rcvd [LCP ConfAck id=0x78 <magic 0xdd4ad820> <pcomp> <accomp>] sent [LCP ConfAck id=0x78 <magic 0xdd4ad820> <pcomp> <accomp>] sent [LCP Ident id=0x7e magic=0x73e981c8 "ppp-2.4.0b1 (Sun Microsystems, Inc., Nov 15 2000 09:38:33)"] sent [IPCP ConfReq id=0x3d <addr 0.0.0.0> <compress VJ 0f 01>] rcvd [LCP Ident id=0x7a magic=0xdd4ad820 "ppp-2.4.0b1 (Sun Microsystems, Inc., Dec 6 2000 09:36:22)"] Peer Identification: ppp-2.4.0b1 (Sun Microsystems, Inc., Dec 6 2000 09:36:22) rcvd [IPCP ConfReq id=0x92 <addr 10.0.0.1> <compress VJ 0f 01> sent [IPCP ConfAck id=0x92 <addr 10.0.0.1> <compress VJ 0f 01> rcvd [IPCP ConfNak id=0x3d <addr 10.0.0.2>]] sent [IPCP ConfReq id=0x3e <addr 10.0.0.2> <compress VJ 0f 01>] rcvd [IPCP ConfAck id=0x3e <addr 10.0.0.2> <compress VJ 0f 01>] local IP address 10.0.0.2 remote IP address 10.0.0.1 |
# pppd /dev/se_hdlc1 default-asyncmap debug updetach pppd 2.4.0b1 (Sun Microsystems, Inc., Oct 24 2001 07:13:18) started by root, uid 0 synchronous speed appears to be 0 bps init option: '/etc/ppp/peers/syncinit.sh' started (pid 105122) Serial port initialized. synchronous speed appears to be 64000 bps Using interface sppp0 Connect: sppp0 <--> /dev/se_hdlc1 sent [LCP ConfReq id=0xe9 <magic 0x474283c6><pcomp> <accomp>] rcvd [LCP ConfAck id=0xe9 <magic 0x474283c6><pcomp> <accomp>] rcvd [LCP ConfReq id=0x22 <magic 0x8e3a53ff><pcomp> <accomp>] sent [LCP ConfReq id=0x22 <magic 0x8e3a53ff><pcomp> <accomp>] sent [LCP Ident id=0xea magic=0x474283c6 "ppp-2.4.0b1 (Sun Microsystems, Inc., Oct 22 2001 14:31:44)"] sent [IPCP ConfReq id=0xf7 <addr 0.0.0.0> <compress VJ Of o1>]] sent [CCP ConfReq id=0x3f <deflate 15> <deflate(old#) 15> <bsd v1 15>] rcvd [LCP Ident id=0x23 magic=0x8e3a53ff "ppp-2.4.0b1 (Sun Microsystems, Inc., Oct 22 2001 14:31:44)"] Peer Identification: ppp-2.4.0b1 (Sun Microsystems, Inc., Oct 22 2001 14:31:44) rcvd [IPCP ConfReq id=0x25 <addr 10.0.0.1> <compress VJ Of 01>] sent [IPCP ConfAck id=0x25 <addr 10.0.0.1> <compress VJ Of 01>] rcvd [CCP ConfReq id=0x3 <deflate 15> <deflate(old#) 15 <bsd v1 15>] sent [CCP ConfAck id=0x3 <deflate 15> <deflate(old#) 15 <bsd v1 15>] rcvd [IPCP ConfNak id=0xf8 <addr 10.0.0.2>] rcvd [IPCP ConfReq id=0xf7 <addr 10.0.0.2> <compress VJ Of 01>] rcvd [CCP ConfAck id=0x3f <deflate 15> <deflate(old#) 15 <bsd v1 15>] Deflate (15) compression enabled rcvd [IPCP ConfAck id=0xf8 <addr 10.0.0.2> <compress VJ Of 01>] local IP address 10.0.0.2 remote IP address 10.0.0.1 |
The next task shows how to use the pppd command to obtain debugging information.
You only need to perform step 1 through step 3 once for each host. Thereafter, you can proceed to step 4 to turn on debugging for the host.
Create a log file to hold output from pppd.
% touch /var/log/pppdebug |
Add the following syslog facilities for pppd in /etc/syslog.conf.
daemon.debug;local2.debug /var/log/pppdebug |
Restart syslogd.
% pkill -HUP -x syslogd |
Turn on debugging for calls to a particular peer by using the following syntax of pppd.
% pppd debug call peer-name |
peer-name must be the name of a file in the /etc/ppp/peers directory.
View the contents of the log file.
% tail -f /var/log/pppdebug |
For an example of a log file, see Example 31–3.
