Symptom |
Problem |
Solution |
pppd debug output shows the message Peer is not authorized to use remote address address. |
You are using PAP authentication, and the IP address for the remote peer is not in the /etc/ppp/pap-secrets file. |
Add an asterisk (*) after the entry for the peer in the /etc/ppp/pap-secrets file. |
pppd debug output shows that LCP starts but terminates shortly afterward. |
The password might be incorrect in the database for the particular security protocol. |
Check the password for the peer in the /etc/ppp/pap-secrets or /etc/ppp/chap-secrets file. |
