System Administration Guide: Resource Management and Network Services
How to Obtain Diagnostic Information From pppd
The next procedure shows how to view the current operation of a link on the local machine.
  1. Become superuser on the local machine.
  2. Run pppd with the serial device configured for PPP as the argument:
    # pppd /dev/ttyname debug updetach
    The next examples show the resulting displays for a dial-up link and a leased-line link when pppd runs in the foreground. If you run pppd debug in the background, the output that is produced is sent to the /etc/ppp/connect-errors file.
    Example 31–1 Output From a Properly Operating Dial-up Link
    # pppd /dev/cua/b debug updetach
    have route to 0.0.0.0/0.0.0.0 via 172.21.0.4
    serial speed set to 230400 bps
    Using interface sppp0
    Connect: sppp0 <--> /dev/cua/b
    sent [LCP ConfReq id=0x7b <asyncmap 0x0> <magic 0x73e981c8> <pcomp> <accomp>]
    rcvd [LCP Ident id=0x79 magic=0x0 "ppp-2.4.0b1 (Sun Microsystems, Inc., Dec  6
    	2000 09:36:22)"]
    Peer Identification: ppp-2.4.0b1 (Sun Microsystems, Inc., Dec  6 2000 09:36:22)
    	rcvd [LCP ConfRej id=0x7b <asyncmap 0x0>]
    sent [LCP Ident id=0x7c magic=0x0 "ppp-2.4.0b1 (Sun Microsystems, Inc., Nov 15
    	2000 09:38:33)"
    sent [LCP ConfReq id=0x7d <magic 0x73e981c8> <pcomp> <accomp>]
    rcvd [LCP ConfAck id=0x7d <magic 0x73e981c8> <pcomp> <accomp>]
    rcvd [LCP ConfAck id=0x78 <magic 0xdd4ad820> <pcomp> <accomp>]
    sent [LCP ConfAck id=0x78 <magic 0xdd4ad820> <pcomp> <accomp>]
    sent [LCP Ident id=0x7e magic=0x73e981c8 "ppp-2.4.0b1 (Sun Microsystems, Inc.,
    	Nov 15 2000 09:38:33)"]
    sent [IPCP ConfReq id=0x3d <addr 0.0.0.0> <compress VJ 0f 01>]
    rcvd [LCP Ident id=0x7a magic=0xdd4ad820 "ppp-2.4.0b1 (Sun Microsystems, Inc.,
    	Dec  6 2000 09:36:22)"]
    rcvd [IPCP ConfReq id=0x92 <addr 10.0.0.1> <compress VJ 0f 01>
    sent [IPCP ConfAck id=0x92 <addr 10.0.0.1> <compress VJ 0f 01>
    rcvd [IPCP ConfNak id=0x3d <addr 10.0.0.2>]]
    sent [IPCP ConfReq id=0x3e <addr 10.0.0.2> <compress VJ 0f 01>]
    rcvd [IPCP ConfAck id=0x3e <addr 10.0.0.2> <compress VJ 0f 01>]
    local  IP address 10.0.0.2
    remote IP address 10.0.0.1
    Example 31–2 Output From a Properly Operating Leased-Line Link
    # pppd /dev/se_hdlc1 default-asyncmap debug updetach
    pppd 2.4.0b1 (Sun Microsystems, Inc., Oct 24 2001 07:13:18) started by root, uid 0
    synchronous speed appears to be 0 bps
    init option: '/etc/ppp/peers/syncinit.sh' started (pid 105122)
    Serial port initialized.
    synchronous speed appears to be 64000 bps
    Connect: sppp0 <--> /dev/se_hdlc1
    sent [LCP ConfReq id=0xe9 <magic 0x474283c6><pcomp> <accomp>]
    rcvd [LCP ConfAck id=0xe9 <magic 0x474283c6><pcomp> <accomp>]
    rcvd [LCP ConfReq id=0x22 <magic 0x8e3a53ff><pcomp> <accomp>]
    sent [LCP ConfReq id=0x22 <magic 0x8e3a53ff><pcomp> <accomp>]
    sent [LCP Ident id=0xea magic=0x474283c6 "ppp-2.4.0b1 (Sun Microsystems, Inc., Oct
    	22 2001 14:31:44)"]
    sent [IPCP ConfReq id=0xf7 <addr 0.0.0.0> <compress VJ Of o1>]]
    sent [CCP ConfReq id=0x3f <deflate 15> <deflate(old#) 15> <bsd v1 15>]
    rcvd [LCP Ident id=0x23 magic=0x8e3a53ff "ppp-2.4.0b1 (Sun Microsystems, Inc., Oct
    	22 2001 14:31:44)"]
    Peer Identification: ppp-2.4.0b1 (Sun Microsystems, Inc., Oct 22 2001 14:31:44)
    rcvd [IPCP ConfReq id=0x25 <addr 10.0.0.1> <compress VJ Of 01>]
    sent [IPCP ConfAck id=0x25 <addr 10.0.0.1> <compress VJ Of 01>]
    rcvd [CCP ConfReq id=0x3 <deflate 15> <deflate(old#) 15 <bsd v1 15>]
    sent [CCP ConfAck id=0x3 <deflate 15> <deflate(old#) 15 <bsd v1 15>]
    rcvd [IPCP ConfNak id=0xf8 <addr 10.0.0.2>]
    rcvd [IPCP ConfReq id=0xf7 <addr 10.0.0.2> <compress VJ Of 01>]
    rcvd [CCP ConfAck id=0x3f <deflate 15> <deflate(old#) 15 <bsd v1 15>]
    Deflate (15) compression enabled
    rcvd [IPCP ConfAck id=0xf8 <addr 10.0.0.2> <compress VJ Of 01>]
