System Administration Guide: Resource Management and Network Services
Parts of a Leased-Line PPP Link
Figure 25–3 Basic Leased-Line Configuration
The graphic shows the parts of a leased-line-link, which are described in the following context.
The leased-line link contains the following parts:
Note –
SONET is called an octet synchronous link. PPP uses a framing mechanism that is similar to asynchronous framing over a SONET line. PPP does not use the expected bit-synchronous protocol.
