The task in this section involves configuring equipment that is required by the leased-line topology that is introduced in Example—Configuration for a Leased-Line Link. The synchronous devices that are required to connect to the leased line include the interface and modem.
Before you perform the next procedure, you must have the following items:
Working leased line that is installed at your site by the provider
Synchronous unit (CSU/DSU)
Solaris 9 operating environment release installed on your system
Synchronous interface card of the type that is required by your system
Physically install the interface card into the local machine, if necessary.
Follow the instructions in the manufacturer's documentation.
Connect the cables from the CSU/DSU to the interface. If necessary, connect cables from the CSU/DSU to the leased-line jack or similar connector.
Configure the CSU/DSU, as instructed in the documentation from the manufacturer or network provider.
The provider from whom you rented the leased line might supply and configure the CSU/DSU for your link.
Configure the interface card, if necessary, as instructed in the interface documentation.
The configuration of the interface card involves the creation of a startup script for the interface. The router at LocalCorp in the leased-line configuration that is shown in Figure 26–2 uses an HSI/S interface card.
The following script hsi-conf starts up the HSI/S interface.
#!/bin/ksh /opt/SUNWconn/bin/hsi_init hih1 speed=1536000 mode=fdx loopback=no \ nrzi=no txc=txc rxc=rxc txd=txd rxd=rxd signal=no 2>&1 > /dev/null |
Indicates that HSI/S is the synchronous port used
Sets the speed of the CSU/DSU to 1536000
Task |
For Instructions |
Configure the local machine on the leased line |
