Dial-up links are the most commonly used PPP links. This section includes the following information:
Planning information for a dial-up link
Explanation of the sample link to be used in Chapter 27, Setting Up a Dial-up PPP Link (Tasks)
Before you configure a dial-out machine, gather the information that is listed in the following table.
The planning information in this section does not include information to be gathered about authentication or PPPoE. For details on authentication planning, refer to Planning for Authentication on a Link. For PPPoE planning, refer to Planning for DSL Support Over a PPPoE Tunnel.
Information |
Action |
Maximum modem speed |
Refer to documentation that was provided by the modem manufacturer. |
Modem connection commands (AT commands) |
Name to use for dial-in server at the other end of the link |
Create any name that helps you identify the dial-in server. |
Login sequence that was required by dial-in server |
Contact the dial-in server's administrator or ISP documentation if dial-in server is at the ISP. |
Before you configure a dial-in server, gather the information that is listed in the following table.
Information |
Action |
User names of people who are permitted to call the dial-in server |
Obtain the names of the prospective users before you set up their home directories, as discussed in How to Configure Users of the Dial-in Server. |
Dedicated IP address for PPP communications |
Obtain an address from the individual at your company who is responsible for delegating IP addresses. |
The tasks to be introduced in Chapter 27, Setting Up a Dial-up PPP Link (Tasks) execute a small company's requirement to let employees work at home a few days a week. Some employees require the Solaris operating environment on their home machines. These workers also need to log in remotely to their work machines on the corporate intranet.
The tasks set up a basic dial-up link with the following features:
The dial-out machines are at the houses of employees who need to call the corporate intranet.
The dial-in server is a machine on the corporate intranet that is configured to receive incoming calls from employees.
UNIX-style login is used to authenticate the dial-out machine. Stronger Solaris PPP 4.0 authentication methods are not required by the company`s security policy.
The next figure shows the link that is set up in Chapter 27, Setting Up a Dial-up PPP Link (Tasks).
In this figure, a remote host dials out through its modem over telephone lines to Big Company's intranet. Another host is configured to dial out to Big Company but currently is inactive. The calls from remote users are answered in the order received by the modem that is attached to the dial-in server at Big Company. A PPP connection is established between the peers. The dial-out machine can then remotely log in to a host machine on the intranet.
Task |
For Information |
Set up a dial-out machine | |
Set up a dial-in machine | |
Get an overview of dial-up links | |
Get detailed information about PPP files and commands |
