If you want to mount file systems at boot time instead of using autofs maps, follow this procedure. This procedure must be completed on every client for remote file systems.
Become superuser or assume an equivalent role.
For information about roles, see “Using Privileged Applications” in System Administration Guide: Security Services.
Add an entry for the file system to /etc/vfstab.
Entries in the /etc/vfstab file have the following syntax:
special fsckdev mountp fstype fsckpass mount-at-boot mntopts
See the vfstab(4) man page for more information.
NFS servers should not have NFS vfstab entries because of a potential deadlock. The NFS service is started after the entries in /etc/vfstab are checked. Consider the following. If two servers that are mounting file systems from each other fail at the same time, each system could hang as the systems reboot.
You want a client machine to mount the /var/mail directory from the server wasp. You want the file system to be mounted as /var/mail on the client and you want the client to have read-write access. Add the following entry to the client's vfstab file.
wasp:/var/mail - /var/mail nfs - yes rw |
