System Administration Guide: Resource Management and Network Services
How to Support Incompatible Client Operating System Versions
  1. Combine the architecture type with a variable that determines the operating system type of the client.
    You can combine the autofs OSREL variable with the CPU variable to form a name that determines both CPU type and OS release.
  2. Create the following map entry.
    bin     aa:/export/local/bin/$CPU$OSREL
    For clients that are running version 5.6 of the operating system, export the following file systems:
    • For SPARC clients – Export /export/local/bin/sparc5.6.
    • For IA clients – Place executables in /export/local/bin/i3865.6.
