You need several files to support NFS activities on any computer. Many of these files are ASCII, but some of the files are data files. Table 15–1 lists these files and their functions.
Table 15–1 NFS Files|
File Name |
Function |
Lists the default file system type for local file systems. |
Lists configuration information for lockd and nfsd. |
Lists configuration information for the NFS server logging daemon, nfslogd. |
/etc/dfs/dfstab |
Lists the local resources to be shared. |
Lists the default file-system types for remote file systems. |
Lists the local and remote resources that are shared. See the sharetab(4) man page. Do not edit this file. |
Lists file systems that are currently mounted, including automounted directories. See the mnttab(4) man page. Do not edit this file. |
/etc/netconfig | |
Lists general configuration information for NFS server logging. |
Lists information for log post-processing by nfslogd. Do not edit this file. |
Lists NFS security services. |
Lists file systems that are remotely mounted by NFS clients. See the rmtab(4) man page. Do not edit this file. |
Defines file systems to be mounted locally. See the vfstab(4) man page. |
The first entry in /etc/dfs/fstypes is often used as the default file-system type for remote file systems. This entry defines the NFS file-system type as the default.
Only one entry is in /etc/default/fs: the default file-system type for local disks. You can determine the file-system types that are supported on a client or server by checking the files in /kernel/fs.
This file defines some of the parameters that are used when using NFS server logging. The following parameters can be defined.
Determines the number of hours that must pass before the log files are cycled. The default value is 24 hours. This option is used to prevent the log files from growing too large.
Sets the number of seconds nfslogd should sleep before checking for more information in the buffer file. This parameter also determines how often the configuration file is checked. This parameter, along with MIN_PROCESSING_SIZE, determines how often the buffer file is processed. The default value is 300 seconds. Increasing this number can improve performance by reducing the number of checks.
Specifies the number of seconds between updates of the records in the file-handle-to-path mapping tables. The default value is 86400 seconds or one day. This parameter helps keep the file-handle-to-path mapping tables up-to-date without having to continually update the tables.
Determines the number of log files to be saved. The default value is 10.
Sets the minimum number of bytes that the buffer file must reach before processing and writing to the log file. This parameter, along with IDLE_TIME, determines how often the buffer file is processed. The default value is 524288 bytes. Increasing this number can improve performance by reducing the number of times the buffer file is processed.
Selects the number of hours that must pass before a file-handle-to-path mapping record times out and can be pruned. The default value is 168 hours or 7 days.
Specifies the file mode creation mask for the log files that are created by nfslogd. The default value is 0137.
This file defines the path, file names, and type of logging to be used by nfslogd. Each definition is associated with a tag. Starting NFS server logging requires that you identify the tag for each file system. The global tag defines the default values. You can use the following parameters with each tag as needed.
Specifies the default directory path for the logging files. Unless you specify differently, the default directory is /var/nfs.
Sets the path and file name for the log files. The default is /var/nfs/nfslog.
Selects the path and file name for the file-handle-to-path database files. The default is /var/nfs/fhtable.
Determines the path and file name for the buffer files. The default is /var/nfs/nfslog_workbuffer.
Selects the format to be used when creating user-readable log files. The basic format produces a log file that is similar to some ftpd daemons. The extended format gives a more detailed view.
If the path is not specified, the path that is defined by defaultdir is used. Also, you can override defaultdir by using an absolute path.
To identify the files more easily, place the files in separate directories. Here is an example of the changes that are needed.
% cat /etc/nfs/nfslog.conf
#ident "@(#)nfslog.conf 1.5 99/02/21 SMI"
# NFS server log configuration file.
global defaultdir=/var/nfs \
log=nfslog fhtable=fhtable buffer=nfslog_workbuffer
publicftp log=logs/nfslog fhtable=fh/fhtables buffer=buffers/workbuffer
In this example, any file system that is shared with log=publicftp would use the following values:
The default directory would be /var/nfs.
Log files would be stored in /var/nfs/logs/nfslog*.
File-handle-to-path database tables would be stored in /var/nfs/fh/fhtables.
Buffer files would be stored in /var/nfs/buffers/workbuffer.
For procedural information, refer to How to Enable NFS Server Logging.
