This command displays one of the following:
All clients that have remotely mounted file systems that are shared from an NFS server
Only the file systems that are mounted by clients
The shared file systems with the client access information
The command syntax is as follows:
showmount [ -ade ] [ hostname ]
Prints a list of all the remote mounts. Each entry includes the client name and the directory.
Prints a list of the directories that are remotely mounted by clients.
Prints a list of the files that are shared or are exported.
Selects the NFS server to gather the information from.
If hostname is not specified the local host is queried.
This command lists all clients and the local directories that the clients have mounted.
# showmount -a bee lilac:/export/share/man lilac:/usr/src rose:/usr/src tulip:/export/share/man |
This command lists the directories that have been mounted.
# showmount -d bee /export/share/man /usr/src |
This command lists file systems that have been shared.
# showmount -e bee /usr/src (everyone) /export/share/man eng |
