System Administration Guide: Resource Management and Network Services
Chapter 12 Resource Control Functionality in the Solaris Management Console
This chapter describes the resource control and performance monitoring features in the Solaris Management Console.
You can use the console to monitor system performance and to enter resource control values for projects, tasks, and processes. The console provides a convenient, secure alternative to the command-line interface (CLI) for managing hundreds of configuration parameters that are spread across many systems. Each system is managed individually. The console's graphical interface supports all experience levels.
Using the Console (Task Map)
Task
Description
For Instructions
Use the console
Start the Solaris Management Console in a local environment or in a name service or directory service environment. Note that the performance tool is not available in a name service environment.
“Starting the Solaris Management Console” in System Administration Guide: Basic Administration and “Using the Solaris Management Tools in a Name Service Environment (Task Map)” in System Administration Guide: Basic Administration
Monitor system performance
Access the Performance tool under System Status.
How to Access the Performance Tool
Add resource controls to projects
Access the Resource Controls tab under System Configuration.
How to Access the Resource Controls Tab
Overview
Resource management functionality is a component of the Solaris Management Console. The console is a container for GUI-based administrative tools that are stored in collections called toolboxes. For information on the console and how to use it, see “Working With the Management Console (Tasks)” in System Administration Guide: Basic Administration.
When you use the console and its tools, the main source of documentation is the online help system in the console itself. For a description of the documentation available in the online help, see “Solaris Management Console (Overview)” in System Administration Guide: Basic Administration.
Management Scope
The term management scope refers to the name service environment that you choose to use with the selected management tool. The management scope choices for the resource control and performance tools are the/etc/project local file, or NIS.
The management scope that you select during a console session should correspond to the primary name service that is identified in the /etc/nsswitch.conf file.
Performance Tool
The Performance tool is used to monitor resource utilization. Resource utilization can be summarized for the system, viewed by project, or viewed for an individual user.
Figure 12–1 Performance Tool in the Solaris Management Console
Screen capture shows Performance under Management Tools in Navigation pane and summary of system performance Attribute and Value pane.
The Performance tool is located under System Status in the Navigation pane. To access the Performance tool, do the following:
  1. Click the System Status control entity in the Navigation pane.
    The control entity is used to expand menu items in the Navigation pane.
  2. Click the Performance control entity.
  3. Click the System control entity.
  4. Double-click Summary, Projects, or Users.
    Your choice depends on the usage you want to monitor.
Monitoring by System
Values are shown for the following attributes.
Attribute
Description
Active Processes
Number of processes that are active on the system
Physical Memory Used
Amount of system memory that is in use
Physical Memory Free
Amount of system memory that is available
Swap Used
Amount of system swap space that is in use
Swap Free
Amount of free system swap space
Page Rate
Rate of system paging activity
System Calls
Number of system calls per second
Network Packets
Number of network packets that are transmitted per second
CPU Usage
Percentage of CPU that is currently in use
Load Average
Number of processes in the system run queue which are averaged over the last 1, 5, and 15 minutes
Monitoring by Project or User Name
Attribute
Short Name
Description
Input Blocks
inblk
Number of blocks read
Blocks Written
oublk
Number of blocks written
Chars Read/Written
ioch
Number of characters read and written
Data Page Fault Sleep Time
dftime
Amount of time spent processing data page faults
Involuntary Context Switches
ictx
Number of involuntary context switches
System Mode Time
stime
Amount of time spent in the kernel mode
Major Page Faults
majfl
Number of major page faults
Messages Received
mrcv
Number of messages received
Messages Sent
msend
Number of messages sent
Minor Page Faults
minf
Number of minor page faults
Num Processes
nprocs
Number of processes owned by the user or the project
Num LWPs
count
Number of lightweight processes
Other Sleep Time
slptime
Sleep time other than tftime, dftime, kftime, and ltime
CPU Time
pctcpu
Percentage of recent CPU time used by the process, the user, or the project
Memory Used
pctmem
Percentage of system memory used by the process, the user, or the project
Heap Size
brksize
Amount of memory allocated for the process data segment
Resident Set Size
rsssize
Current amount of memory claimed by the process
Process Image Size
size
Size of the process image in Kbytes
Signals Received
sigs
Number of signals received
Stopped Time
stoptime
Amount of time spent in the stopped state
Swap Operations
swaps
Number of swap operations in progress
System Calls Made
sysc
Number of system calls made over the last time interval
System Page Fault Sleep Time
kftime
Amount of time spent processing page faults
System Trap Time
ttime
Amount of time spent processing system traps
Text Page Fault Sleep Time
tftime
Amount of time spent processing text page faults
User Lock Wait Sleep Time
ltime
Amount of time spent waiting for user locks
User Mode Time
utime
Amount of time spent in the user mode
User and System Mode Time
time
The cumulative CPU execution time
Voluntary Context Switches
vctx
Number of voluntary context switches
Wait CPU Time
wtime
Amount of time spent waiting for CPU (latency)
Resource controls allow you to associate a project with a set of resource constraints. These constraints determine the allowable resource usage of tasks and processes that run in the context of the project.
Figure 12–2 Resource Controls Tab in the Solaris Management Console
Screen capture shows the Resource Controls tab. Resource controls and their values appear on the tab.
The Resource Controls tab is located under System Configuration in the Navigation pane. To access Resource Controls, do the following:
  1. Click the System Configuration control entity in the Navigation pane.
  2. Double-click Projects.
  3. Click on a project in the console main window to select it.
  4. Select Properties from the Action menu.
  5. Click the Resource Controls tab.
    View, add, edit, or delete resource control values for processes, projects, and tasks.
Resource Controls You Can Set
To view the list of available resource controls, see About Resource Controls in the console or Available Resource Controls.
Setting Values
You can view, add, edit, or delete resource control values for processes, projects, and tasks. These operations are performed through dialog boxes in the console.
Resource controls and values are viewed in tables in the console. The Resource Control column lists the resource controls that can be set. The Value column displays the properties that are associated with each resource control. In the table, these values are enclosed in parentheses, and they appear as plain text separated by commas. The values in parentheses comprise an “action clause.” Each action clause is composed of a threshold, a privilege level, one signal, and one local action that is associated with the particular threshold. Each resource control can have multiple action clauses, which are also separated by commas.
Note –
On a running system, values that are altered in the project database through the console only take effect for new tasks that are started in a project.
References
For information on projects and tasks, see Chapter 5, Projects and Tasks. For information on resource controls, see Chapter 7, Resource Controls. For information on the fair share scheduler (FSS), see Chapter 8, Fair Share Scheduler.
