System Administration Guide: Resource Management and Network Services
How to Print the Contents of an exacct File
Use the following Perl script to print the contents of an exacct file.
#!/usr/perl5/5.6.1/bin/perl
     use strict;
     use warnings;
     use Sun::Solaris::Exacct qw(:EXACCT_ALL);
     die("Usage is dumpexacct <exacct file>\n") unless (@ARGV == 1);
     # Open the exact file and display the header information.
     my $ef = ea_new_file($ARGV[0], &O_RDONLY) || die(error_str());
     printf("Creator:  %s\n", $ef->creator());
     printf("Hostname: %s\n\n", $ef->hostname());
     # Dump the file contents
     while (my $obj = $ef->get()) {
             ea_dump_object($obj);
     # Report any errors
     if (ea_error() != EXR_OK && ea_error() != EXR_EOF)  {
             printf("\nERROR: %s\n", ea_error_str());
             exit(1);
     exit(0);
