The commands that are shown in the following table provide the primary administrative interface to the pools facility.
Command |
Description |
Activates a particular configuration or deactivates the current configuration. If run without options, pooladm prints out the current running pools configuration. |
Enables the manual binding of projects, tasks, and processes to a pool. |
Creates and modifies pools configuration files. If run with the info subcommand argument to the -c option, poolcfg displays the current configuration. |
A library API is provided by libpool(3LIB). The library can be used by programs to manipulate pool configurations.
