If you select files as your project database in nsswitch.conf, the login process searches the /etc/project file for project information (see projects(1) and project(4)). The project file contains a one-line entry for each project recognized by the system, of the following form:
projname:projid:comment:user-list:group-list:attributes |
The fields are defined as follows.
The name of the project. The name must be a string that consists of alphanumeric characters, the underline (_) character, and the hyphen (-). The name must begin with an alphabetic character. projname cannot contain periods (.), colons (:), or newline characters.
The project's unique numerical ID (PROJID) within the system. The maximum value of the projid field is UID_MAX (2147483647).
The project's description.
A comma-separated list of users who are allowed in the project.
Wildcards can be used in this field. The asterisk (*) allows all users to join the project. The exclamation point followed by the asterisk (!*) excludes all users from the project. The exclamation mark (!) followed by a user name excludes the specified user from the project.
A comma-separated list of groups of users who are allowed in the project.
Wildcards can be used in this field. The asterisk (*) allows all groups to join the project. The exclamation point followed by the asterisk (!*) excludes all groups from the project. The exclamation mark (!) followed by a group name excludes the specified group from the project.
A semicolon-separated list of name-value pairs (see Chapter 7, Resource Controls). name is an arbitrary string that specifies the object-related attribute, and value is the optional value for that attribute.
name[=value] |
In the name-value pair, names are restricted to letters, digits, underscores, and the period. The period is conventionally used as a separator between the categories and subcategories of the rctl. The first character of an attribute name must be a letter. The name is case sensitive.
Values can be structured by using commas and parentheses to establish precedence. The semicolon is used to separate name-value pairs. The semicolon cannot be used in a value definition. The colon is used to separate project fields. The colon cannot be used in a value definition.
Routines that read this file halt when they encounter a malformed entry. Any project assignments that are specified after the incorrect entry are not made.
This example shows the default /etc/project file:
system:0:System::: user.root:1:Super-User::: noproject:2:No Project::: default:3:::: group.staff:10:::: |
This example shows the default /etc/project file with project entries added at the end:
system:0:System::: user.root:1:Super-User::: noproject:2:No Project::: default:3:::: group.staff:10:::: user.ml:2424:Lyle Personal::: booksite:4113:Book Auction Project:ml,mp,jtd,kjh:: |
To add resource controls to the /etc/project file, see Using Resource Controls.
