The /etc/uucp/Systems file contains the information that is needed by the uucico daemon to establish a communication link to a remote computer. /etc/uucp/Systems is the first file you need to edit to configure UUCP.
Each entry in the Systems file represents a remote computer with which your host communicates. A particular host can have more than one entry. The additional entries represent alternative communication paths that are tried in sequential order. In addition, by default UUCP prevents any computer that does not appear in /etc/uucp/Systems from logging in to your host.
Using the Sysfiles file, you can define several files to be used as Systems files. See UUCP /etc/uucp/Sysfiles File for a description of Sysfiles.
Each entry in the Systems file has the following format:
System-Name |
Time |
Type |
Speed |
Phone |
Chat Script |
The following example shows the fields of the Systems file.
System-Name Time Type Speed Phone Chat Script Arabian Any ACUEC 38400 111222 Login: Puucp ssword:beledi |
This field contains the node name of the remote computer. On TCP/IP networks, this name can be the machine's host name or a name that is created specifically for UUCP communications through the /etc/uucp/Sysname file. See UUCP /etc/uucp/Systems File. In Example 36–1, the System-Name field contains an entry for remote host arabian.
This field specifies the day of week and time of day when the remote computer can be called. The format of the Time field follows:
daytime[;retry]
The day portion can be a list that contains some of the following entries.
Table 36–1 Day Field|
For individual days. |
For any weekday. |
For any day. |
Your host never initiates a call to the remote computer. The call must be initiated by the remote computer. Your host is then operating in passive mode. |
Example 36–1 shows Any in the Time field, which indicates that host arabian can be called at any time.
The time portion should be a range of times that are specified in 24-hour notation, for example, 0800-1230 for 8:30 a.m. to 12:30 p.m. If no time portion is specified, any time of day is assumed to be allowed for the call.
A time range that spans 0000 is permitted. For example, 0800-0600 means all times are allowed other than times between 6 a.m. and 8 a.m.
The Retry subfield enables you to specify the minimum time (in minutes) before a retry, following a failed attempt. The default wait is 60 minutes. The subfield separator is a semicolon (;). For example, Any;9 is interpreted as call any time, but wait at least 9 minutes before retrying after a failure occurs.
If you do not specify a retry entry, an exponential back-off algorithm is used. This means that UUCP starts with a default wait time that grows larger as the number of failed attempts increases. For example, suppose the initial retry time is 5 minutes. If no response occurs, the next retry is 10 minutes later. The next retry is 20 minutes later, and so on until the maximum retry time of 23 hours is reached. If retry is specified, that is always the retry time. Otherwise, the back-off algorithm is used.
This field contains the device type that should be used to establish the communication link to the remote computer. The keyword that is used in this field is matched against the first field of Devices file entries.
File Name System-Name Time Type Speed Phone Chat Script Systems arabian Any ACUEC, g 38400 1112222 ogin: Puucp ssword:beledi |
You can define the protocol that is used to contact the system by adding it on to the Type field. The previous example shows how to attach the protocol g to the device type ACUEC. For information on protocols, see UUCP Protocol Definitions in the Devices File.
This field (also known as the Class field) specifies the transfer speed of the device that is used in establishing the communication link. The UUCP speed field can contain a letter and speed (for example, C1200, D1200) to differentiate between classes of dialers (refer to UUCP Class Field).
Some devices can be used at any speed, so the keyword Any can be used. This field must match the Class field in the associated Devices file entry.
File Name System-Name Time Type Speed Phone Chat Script Systems eagle Any ACU, g D1200 NY3251 ogin: nuucp ssword: Oakgrass |
If information is not required for this field, use a dash (-) as a placeholder for the field.
This field enables you to specify the telephone number (token) of the remote computer for automatic dialers (port selectors). The telephone number consists of an optional alphabetic abbreviation and a numeric part. If an abbreviation is used, it must be one that is listed in the Dialcodes file.
File Name System-Name Time Type Speed Phone Chat Script Systems nubian Any ACU 2400 NY5551212 ogin: Puucp ssword:Passuan |
In the System-Name string, an equals sign (=) tells the ACU to wait for a secondary dial tone before dialing the remaining digits. A dash (-) in the string instructs the ACU to pause four seconds before dialing the next digit.
If your computer is connected to a port selector, you can access other computers that are connected to that selector. The Systems file entries for these remote machines should not have a telephone number in the Phone field. Instead, this field should contain the token to be passed on to the switch. In this way, the port selector knows the remote machine with which your host wants to communicate, usually just the system name. The associated Devices file entry should have a \D at the end of the entry to ensure that this field is not translated by using the Dialcodes file.
This field (also called the Login field) contains a string of characters that is called a chat-script. The chat-script contains the characters the local and remote machines must pass to each other in their initial conversation. Chat-scripts have the following format:
expect send [expect send] ....
expect represents the string that the local host expects to receive from the remote host to initiate conversation. send is the string the local host sends after it receives the expect string from the remote host. A chat-script can have more than one expect-send sequence.
A basic chat-script might contain the following:
Login prompt that the local host expects to receive from the remote machine
Login name that the local host sends to the remote machine in order to log in
Password prompt that the local host expects to receive from the remote machine
Password that the local host sends to the remote machine
The expect field can be composed of subfields of the following form:
expect[-send-expect]...
send is sent if the prior expect is not successfully read, and the -expect that follows the send is the next expected string.
For example, with strings login--login, the UUCP on the local host expects login. If UUCP receives login from the remote machine, it goes to the next field. If it does not receive login, it sends a carriage return, then looks for login again. If the local computer initially does not expect any characters, use the characters "" (NULL string) in the expect field. All send fields are sent with a carriage return appended unless the send string is terminated with a \c.
Here is an example of a Systems file entry that uses an expect-send string:
System-Name Time Type Speed Phone Chat Script sonora Any ACUEC 9600 2223333 "" \r \r ogin:-BREAK-ogin: Puucpx ssword: xyzzy |
This example tells UUCP on the local host to send two carriage returns and wait for ogin: (for Login:). If ogin: is not received, send a BREAK. When you do receive ogin: send the login name Puucpx. When you receive ssword: (for Password:), send the password xyzzy.
The following table lists some useful escape characters.
Table 36–2 Escape Characters Used in Systems File Chat Script| Escape Character | Meaning |
Sends or expects a backspace character. |
If at the end of a string, suppresses the carriage return that is normally sent. Ignored otherwise. |
Delays 1–3 seconds before sending more characters. |
Starts echo checking. From this point on, whenever a character is transmitted, UUCP waits for the character to be received before continuing its checks. |
Echoes check-off. |
Ignores one hangup. Use this option for dialback modems. |
Sends a BREAK character. |
Turns on CLOCAL flag. |
Turns off CLOCAL flag. |
Sends or expects a newline character. |
Sends a NULL character (ASCII NUL). |
Pauses for approximately 1/4 to 1/2 second. |
Sends or expects a carriage return. |
Sends or expects a space character. |
Sends or expects a tab character. |
Sends an EOT, followed by newline twice. |
Sends a break character. |
Sends or expects the character that is represented by the octal digits (ddd). |
Some companies set up dial-in servers to handle calls from remote computers. For example, your company might have a dial-in server with a dialback modem that employees can call from their home computers. After the dial-in server identifies the remote machine, it disconnects the link to the remote machine and then calls back the remote machine. The communications link is then reestablished.
You can facilitate dialback by using the \H option in the Systems file chat-script at the place where dialback should occur. Include the \H as part of an expect string at the place where the dial-in server is expected to hang up.
For example, suppose the chat-script that calls a dial-in server contains the following string:
INITIATED\Hogin: |
The UUCP dialing facility on the local machine expects to receive the characters INITIATED from the dial-in server. After the INITIATED characters have been matched, the dialing facility flushes any subsequent characters it receives until the dial-in server hangs up. The local dialing facility then waits until it receives the next part of the expect string, the characters ogin:, from the dial-in server. When it receives the ogin:, the dialing facility then continues through the chat-script.
You need not to have a string of characters directly preceding or following the \H, as shown in the previous sample string.
You can also use the pseudo-send STTY=value string to set modem characteristics. For instance, STTY=crtscts enables hardware flow control. STTY accepts all stty modes. See the stty(1) and termio(7I) man pages for complete details.
The following example would enable hardware flow control in a Systems file entry:
System-Name Time Type Speed Phone Chat Script unix Any ACU 2400 12015551212 "" \r login:-\r-login:-\r-login: nuucp password: xxx "" \ STTY=crtscts |
This pseudo-send string can also be used in entries in the Dialers file.
In some situations, you have to reset the parity because the system that you are calling checks port parity and drops the line if it is wrong. The expect-send couplet "" P_ZERO sets the high-order bit (parity bit) to 0. For example:
System-Name Time Type Speed Phone Chat Script unix Any ACU 2400 12015551212 "" P_ZERO "" \r login:-\r-login:-\r-login: nuucp password: xxx |
In the same manner, P_EVEN sets parity to even (the default), P_ODD sets odd parity, and P_ONE sets the parity bit to 1.
The parity couplet can be inserted anywhere in the chat-script. The couplet applies to all information in the chat-script that follows the "" P_ZERO. The couplet can also be used in entries in the Dialers file.
