System Administration Guide: Resource Management and Network Services
UUCP Administrative Files
The UUCP administrative files are described next. These files are created in spool directories to lock devices, hold temporary data, or keep information about remote transfers or executions.
Table 36–10 UUCP Lock Files
File Name
Description
LCK..sys
sys represents the name of the computer that is using the file
LCK.dev
dev represents the name of a device that is using the file
LCK.LOG
LOG represents a locked UUCP log file
These files can remain in the spool directory if the communications link is unexpectedly dropped (usually on computer crashes). The lock file is ignored (removed) after the parent process is no longer active. The lock file contains the process ID of the process that created the lock.
