The following table provides pointers to the procedures that are covered in this chapter, in addition to a short description of each procedure.
Table 35–1 Task Map: UUCP Administration|
Task |
Description |
For Instructions |
Allow remote machines to have access to your system |
Edit the /etc/passwd file to add entries to identify the machines that are permitted to access your system. | |
Start UUCP |
Use the supplied shell scripts to start UUCP. | |
Enable UUCP to work with TCP/IP |
Edit /etc/inetd.conf and /etc/uucp/Systems files to activate UUCP for TCP/IP. | |
Troubleshoot some common UUCP problems |
Diagnostic steps to use to check for faulty modems or ACUs. Diagnostic steps to use for debugging transmissions. |
