System Administration Guide: Resource Management and Network Services
Controlling Access to Files on the FTP Server
The FTP server access controls in this section supplement the standard file and directory access controls available with the Solaris 9 operating environment. Use the standard Solaris commands to restrict who can access, change, or upload files. See chmod(1), chown(1), and chgrp(1).
How to Control File Access Commands
To use the permission capabilities in ftpaccess to specify what type of user is allowed to perform which commands, do the following:
  1. Become superuser.
  2. Add the following entries to the ftpaccess :
    command yes|no typelist
    command
    The commands chmod, delete, overwrite, rename, or umask
    yes|no
    Allows or disallows a user to issue a command
    typelist
    A comma-separated list of any of the keywords anonymous, guest, and real
Example—How to Control File Access Commands
The following are examples of permissions that are set for file access functions on FTP server.
chmod no anonymous, guest
delete    no anonymous
overwrite no anonymous
rename    no anonymous
umask     no guest, anonymous
The preceding example states the following:
