The FTP Server is compatible with Solaris 8 FTP software, yet offers new capability with improved performance for Solaris 9 users.
Table 37–1 What's New for the Solaris 9 FTP Server|
Feature |
Description |
For Information |
User classification by type and location |
Permits you to define a class of users, based on type and address | How to Define FTP Server Classes |
Limits per class |
Controls the number of users from a certain class who are allowed simultaneous login, based on limits that are set in the ftpaccess file | How to Set User Login Limits |
System-wide and directory-related messages |
Displays the messages that you specify for particular events | How to Create Messages to Be Sent to Users |
Upload permissions per directory |
Allows you to control uploads to the FTP Server, including file and directory creation and permissions | How to Control Uploads to the FTP Server |
File name filter |
Enables you to specify which characters, in what sequence, are acceptable in the name of an uploaded file | How to Control Uploads to the FTP Server |
Virtual host support |
Permits you to configure the FTP server to support multiple domains on a single machine | How to Enable Complete Virtual Hosting |
Command logging |
Allows logging of commands that are executed by real, guest, and anonymous FTP users | How to Check the Commands Executed by FTP Users |
Transfer logging |
Allows logging of transfers for real, guest, and anonymous FTP users | ftpaccess(4), xferlog(4), in.ftpd(1M) |
As-needed compression and archiving |
Allows as-needed compression and archiving by using conversions that are specified in the ftpconversions file | ftpconversions(4), ftpaccess(4) |
The Solaris 8 /etc/default/ftpd is not supported in the Solaris 9 release. During upgrade, BANNER and UMASK entries are converted to their wu-ftpd equivalents. However, the system administrator might need to manually convert some BANNER lines for the equivalent ftpaccess greeting capability. For further information, see ftpaccess(4).
The sublogin feature that is provided by the Solaris 8 FTP Server is not supported by the Solaris 9 FTP Server.
