PMTAG
Identifies the port monitor name, mbmon.
PMTYPE
Identifies the port monitor type, ttymon.
FLGS
Indicates whether the following flags
are set:
d, do not enable the new port monitor
x, do not start the new port monitor
dash (-), no flags are set
RCNT
Indicates the return count value. A
return count of 0 indicates that the port monitor is not
to be restarted if it fails.
STATUS
Indicates the current status of the
port monitor.
COMMAND
Identifies the command used to start
the port monitor.
#TTY Ports a &
b
Identifies
any comment used to describe the port monitor.
