System Administration Guide: Advanced Administration
The /etc/saf/_sactab File
The /etc/saf/_sactab is as follows:
# VERSION=1
zsmon:ttymon::0:/usr/lib/saf/ttymon     #
# VERSION=1
Indicates the Service Access Facility version number.
zsmon
Is the name of the port monitor.
ttymon
Is the type of port monitor.
Indicates whether the following two flags are set:
d, do not enable the port monitor
x, do not start the port monitor. No flags are set in this example.
0
Indicates the return code value. A return count of 0 indicates that the port monitor is not be restarted if the port monitor fails.
/usr/lib/saf/ttymon
Indicates the port monitor pathname.
