The following example shows a print filter definition to convert N37 or Nlp to simple.
Input types: N37, Nlp, simple Output types: simple Command: /usr/bin/col Options: MODES expand = -x Options: INPUT simple = -p -f |
In this example, the print filter program is named col. Once you add the new print filter to a print server, a user's print requests will be handled as follows:
When a user enters the following command:
$ lp -y expand report.doc |
The print filter program is run with the following arguments to convert the file:
/usr/bin/col -x -p -f |
$ lp -T N37 -y expand report.doc |
/usr/bin/col -x |
The following example shows a print filter definition to convert from troff to PostScript.
Input types: troff Output types: postscript Printer types: PS Filter type: slow Command: /usr/lib/lp/postscript/dpost Options: LENGTH * = -l* Options: MODES port = -pp, MODES land = -pl Options: MODES group \=\([1-9]\) = -n\l |
In this example, the filter program is named dpost. It takes one input type, troff, produces a postscript output, and works with any printer of type PS (PostScript). Users need to give just the abbreviation port or land when they ask for the paper orientation to be in portrait mode or landscape mode. Because these options are not intrinsic to the LP print service, users must specify them using the lp -y command.
After you add the new print filter to a print server, print requests will be handled as follows:
When a user enters the following command to submit a troff file type for printing on a PostScript printer (type PS), with requests for landscape orientation and a page length of 60 lines:
$ lp -T troff -o length=60 -y land -d luna ch1.doc |
The print filter program dpost is run with the following arguments to convert the file:
/usr/lib/lp/postscript/dpost -l60 -pl |
$ lp -T troff -y group=4 -d luna ch1.doc |
/usr/lib/lp/postscript/dpost -n4 |
