System Administration Guide: Advanced Administration
How to Check Page-In Activity (sar -p)
Use the sar -p command to report page-in activity, which includes protection and translation faults.
$ sar -p
00:00:00  atch/s  pgin/s ppgin/s  pflt/s  vflt/s slock/s
01:00:00    0.07    0.00    0.00    0.21    0.39    0.00
The following table describes the reported statistics from the -p option.
Table 24–14 Output From the sar -p Command
Field Name
Description
atch/s
The number of page faults, per second, that are satisfied by reclaiming a page currently in memory (attaches per second). Instances include reclaiming an invalid page from the free list and sharing a page of text that is currently being used by another process. For example, two or more processes that are accessing the same program text.
pgin/s
The number of times, per second, that file systems receive page-in requests.
ppgin/s
The number of pages paged in, per second. A single page-in request, such as a soft-lock request (see slock/s), or a large block size, might involve paging-in multiple pages.
pflt/s
The number of page faults from protection errors. Instances of protection faults are illegal access to a page and “copy-on-writes.” Generally, this number consists primarily of “copy-on-writes.”
vflt/s
The number of address translation page faults, per second. These faults are known as validity faults, and occur when a valid process table entry does not exist for a given virtual address.
slock/s
The number of faults, per second, caused by software lock requests that require physical I/O. An example of the occurrence of a soft-lock request is the transfer of data from a disk to memory. The system locks the page that is to receive the data, so that the page cannot be claimed and used by another process.
Example—Checking Page-In Activity
The following example shows output from the sar -p command.
$ sar -p
SunOS touchstone 5.9 Generic sun4u    03/04/2003
01:00:00    1.00    0.00    0.00    0.26    1.13    0.00
02:00:00    1.00    0.00    0.00    0.26    1.13    0.00
03:00:00    1.01    0.00    0.00    0.29    1.17    0.00
04:00:00    1.03    0.00    0.00    0.34    1.27    0.00
05:00:00    1.00    0.00    0.00    0.26    1.13    0.00
06:00:00    1.00    0.00    0.00    0.26    1.13    0.00
07:00:00    1.00    0.00    0.00    0.26    1.13    0.00
08:00:00    1.00    0.00    0.00    0.26    1.13    0.00
08:20:01    1.03    0.00    0.00    0.32    1.26    0.00
08:40:00    1.03    0.00    0.00    0.32    1.26    0.00
09:00:00    1.03    0.00    0.00    0.42    1.43    0.00
09:20:01    2.17    1.37    1.95    2.59   50.06    0.00
09:40:01    0.09    0.52    0.63    0.27  105.42    0.00
10:00:02    0.65    2.59    3.11    1.19   42.19    0.00
10:20:03    1.69   11.45   13.77    4.36   39.58    0.00
10:40:01    0.08    0.31    0.32    1.56   12.23    0.00
Average     1.00    0.51    0.62    0.55    8.79    0.00
