This modified adm crontab contains entries for the ckpacct, runacct, and monacct scripts.
#ident "@(#)adm 1.5 92/07/14 SMI" /* SVr4.0 1.2 */ # # The adm crontab file should contain startup of performance # collection if the profiling and performance feature has been # installed. 0 * * * * /usr/lib/acct/ckpacct 30 2 * * * /usr/lib/acct/runacct 2> /var/adm/acct/nite/fd2log 30 7 1 * * /usr/lib/acct/monacct |
This modified root crontab contains entries for the dodisk program.
#ident "@(#)root 1.19 98/07/06 SMI" /* SVr4.0 1.1.3.1 */ # # The root crontab should be used to perform accounting data collection. # # The rtc command is run to adjust the real time clock if and when # daylight savings time changes. # 10 3 * * * /usr/sbin/logadm 15 3 * * 0 /usr/lib/fs/nfs/nfsfind 1 2 * * * [ -x /usr/sbin/rtc ] && /usr/sbin/rtc -c > /dev/null 2>&1 30 3 * * * [ -x /usr/lib/gss/gsscred_clean ] && /usr/lib/gss/gsscred_clean 30 22 * * 4 /usr/lib/acct/dodisk |
The following example shows a sample /etc/acct/holidays file.
* @(#)holidays January 1, 2002 * * Prime/Nonprime Table for UNIX Accounting System * * Curr Prime Non-Prime * Year Start Start * 2002 0800 1800 * * only the first column (month/day) is significant. * * month/day Company * Holiday * 1/1 New Years Day 7/4 Indep. Day 12/25 Christmas |
