Display information about how disk space is used by using the df command.
$ df [directory] [-h] [-t] [-t] |
df |
With no options, lists all mounted file systems and their device names, the number of 512-byte blocks used, and the number of files. |
directory |
Specifies the directory whose file system you want to check. |
-h |
Displays disk space in the power of 1024. |
-t |
Displays the total blocks as well as the blocks used for all mounted file systems. |
In the following example, all the file systems listed are locally mounted except for /usr/dist, which is mounted remotely from the system venus.
$ df / (/dev/dsk/c0t0d0s0 ): 287530 blocks 92028 files /usr (/dev/dsk/c0t0d0s6 ): 1020214 blocks 268550 files /proc (/proc ): 0 blocks 878 files /dev/fd (fd ): 0 blocks 0 files /etc/mnttab (mnttab ): 0 blocks 0 files /var/run (swap ): 396016 blocks 9375 files /tmp (swap ): 396016 blocks 9375 files /opt (/dev/dsk/c0t0d0s5 ): 381552 blocks 96649 files /export/home (/dev/dsk/c0t0d0s7 ): 434364 blocks 108220 files /usr/dist (venus:/usr/dist ):14750510 blocks 2130134 files |
In the following example, file system information is displayed in 1024 bytes.
$ df -h Filesystem size used avail capacity Mounted on /dev/dsk/c0t0d0s0 1.9G 58M 1.8G 4% / /dev/dsk/c0t0d0s6 2.5G 765M 1.7G 1% /usr /proc 0K 0K 0K 0% /proc fd 0K 0K 0K 0% /dev/fd mnttab 0K 0K 0K 0% /etc/mnttab swap 2.1G 24K 2.1G 1% /var/run swap 2.1G 0K 2.1G 0% /tmp /dev/dsk/c0t0d0s5 1.9G 12M 1.8G 1% /opt /dev/dsk/c0t0d0s7 1.9G 10K 1.8G 1% /export/home |
Although /proc and /tmp are local file systems, they are not UFS file systems. /proc is a PROCFS file system, /var/run and /tmp are TMPFS file systems, and /etc/mnttab is a MNTFS file system.
The following example shows a list of all mounted file systems, device names, total 512-byte blocks used, and number of files. The second line of each two-line entry displays the total number of blocks and files allocated for the file system.
$ df -t
total: 385614 blocks 96832 files
total: 2381102 blocks 300288 files
/proc (/proc ): 0 blocks 879 files
total: 0 blocks 924 files
total: 0 blocks 72 files
total: 0 blocks 1 files
/var/run (swap ): 396112 blocks 9375 files
total: 396112 blocks 9395 files
/tmp (swap ): 396112 blocks 9375 files
total: 396128 blocks 9395 files
total: 434382 blocks 108224 files
/usr/dist (venus:/usr/dist ): 14750510 blocks 2130134 files
total: 41225162 blocks 2482176 files
