Use the isainfo command to determine if a system has 64-bit capabilities enabled, which means that the system is booted with the 64–bit kernel.
The output for an UltraSPARC system running a 32-bit kernel appears as follows:
$ isainfo -v 32-bit sparc applications |
This output means that this system is capable of supporting only 32-bit applications.
The output for an UltraSPARC system running a 64-bit kernel appears as follows:
$ isainfo -v 64-bit sparcv9 applications 32-bit sparc applications |
This output means that this system is capable of supporting both 32-bit and 64-bit applications.
Use the isainfo -b command to display the number of bits supported by native applications on the running system.
The output from a SPARC, x86, or UltraSPARC system running the 32–bit Solaris operating environment appears as follows:
$ isainfo -b 32 |
The output from a 64–bit UltraSPARC system running the 64–bit Solaris operating environment appears as follows:
$ isainfo -b 64 |
The command returns 64 only. Even though a 64–bit UltraSPARC system is capable of running both types of applications, 64–bit applications are the best kind of applications to run on a 64–bit system.
