Solaris Tunable Parameters Reference Manual
shmsys:shminfo_shmmax (Solaris 9 12/02)
Description
Maximum size of system V shared memory segment that can be created. This parameter is an upper limit that is checked before the system sees if it actually has the physical resources to create the requested memory segment.
Attempts to create a shared memory section whose size is zero or whose size is larger than the specified value will fail with an EINVAL error.
Data Type
Unsigned long
Default
8,388,608
Range
0 - MAXINT on 32-bit systems, MAXINT64 on 64-bit systems
Units
Bytes
Dynamic?
No. Loaded into shmmax field of shminfo structure.
Validation
None
When to Change
When the default value is too low. Generally changed at the recommendation of software vendors, but unless the size of a shared memory segment needs to be constrained, setting this parameter to the maximum possible value has no side effects.
Commitment Level
Unstable
