You can use variables in the required information files, pkginfo and prototype, as well as an option to the pkgmk command (which is used to build a package). As each of these files and commands are discussed in this chapter, more context-sensitive information on variables is provided. However, before you begin building your package, you should understand the different types of variables and how they can affect a package's successful creation.
There are two types of variables:
Build variables begin with a lowercase letter and are evaluated at build time (as the package is being built with the pkgmk command).
Install variables begin with an uppercase letter and are evaluated at install time (as the package is being installed with the pkgadd command).
In the pkginfo file, a variable definition is of the form PARAM=value, where the first letter of PARAM is an uppercase letter. These variables are evaluated only at install time, and if any cannot be evaluated, the pkgadd command will abort with an error.
In the prototype file, a variable definition can take the form !PARAM=value or $variable. Both PARAM and variable can begin with either an uppercase or lowercase letter; however, only variables whose values are known at build time will be evaluated. This means that if PARAM or variable is a build or install variable whose value is not known at build time, the pkgmk command will abort with an error.
You can also include the option PARAM=value as an option to the pkgmk command. This option works the same as in the prototype file, except that its scope is global to the entire package. The !PARAM=value definition in a prototype file is local to that file and the part of the package it defines.
If PARAM is an install variable, and variable is an install or build variable with a known value, the pkgmk command inserts the definition into the pkginfo file so that it will be available at install time. However, it will not evaluate PARAM in any path names specified in the prototype file.
The table below summarizes variable specification formats, location, and scope.
Table 2–2 Package Environment Variables Summary|
Variable Defined In The ... |
Variable Definition Format |
Variable Type Being Defined |
When The Variable Is Resolved |
Where The Variable Is Resolved |
The Variable May Be Used As Part Of The ... |
pkginfo file |
PARAM=value |
Build |
Ignored at build time |
N/A |
None |
Install |
Install time |
In the pkgmap file |
owner, group, path, or link target |
prototype file |
!PARAM=value |
Build |
Build time |
In the prototype file and any included files |
mode, owner, group, or path |
Install |
Build time |
!search and !command commands only |
pkgmk command line |
PARAM=value |
Build |
Build time |
In the prototype file |
Install |
Build time |
!search command only |
Install time |
