Application Packaging Developer's Guide
Chapter 3 Enhancing the Functionality of a Package
This chapter describes how to create optional information files and installation scripts for a package. While Chapter 2, Building a Package discussed the minimum requirements for making a package, this chapter discusses additional functionality that you can build into a package, based on the criteria you considered when planning how to design your package (for more information, see Things to Think About Before Building a Package).
This is a list of the overview information in this chapter.
Creating Information Files and Installation Scripts Task Map
The table below lists and describes the optional features you can build into a package.
Table 3–1 Creating Information Files and Installation Scripts Task Map
Task
Description
For Instructions, Go To ...
1. Create Information Files
Define Package Dependencies
A definition of package dependencies allows you to specify whether your package is compatible with previous versions, dependent on other packages, or whether other packages are dependent on yours.
How to Define Package Dependencies
Provide a Copyright Message
A copyright file provides legal protection for your software application.
How to Write a Copyright Message
Create Additional Space on the Target System.
A space file sets aside blocks on the target system, which enables you to create files during installation that are not defined in the pkgmap file.
How to Reserve Additional Space on a Target System
2. Create Installation Scripts
Obtain Information From the Installer
A request script enables you to obtain information from the person installing your package.
How to Write a request Script
Gather File System Data Needed For Installation
A checkinstall script enables you to perform an analysis of the target system and set up the correct environment for, or cleanly halt, the installation.
How to Gather File System Data
Write Procedure Scripts
Enables you to provide customized installation instructions during specific phases of the installation or removal process.
How to Write Procedure Scripts
Write Class Action Scripts
Enables you to specify a set of instructions to be executed during package installation and removal on specific groups of package objects.
How to Write Class Action Scripts
This section discusses optional package information files. With these files you can define package dependencies, provide a copyright message, and reserve additional space on a target system.
Defining Package Dependencies
You need to determine whether your package has dependencies on other packages and if any other packages depend on yours. Package dependencies and incompatibilities can be defined with two of the optional package information files, compver and depend. Delivering a compver file lets you name previous versions of your package that are compatible with the one being installed. Delivering a depend file lets you define three types of dependencies associated with your package. These dependency types are:
The depend file resolves only very basic dependencies. If your package depends upon a specific file or its contents or behavior, the depend file does not supply adequate precision. In this case, a request script or the checkinstall script should be used for detailed dependency checking. The checkinstall script is also the only script capable of cleanly halting the package installation process.
Note –
Be certain that your depend and compver files have entries in the prototype file. The file type should be i (for package information file).
Refer to depend(4) and compver(4) for more information.
  1. Make the directory containing your information files the current working directory.
  2. If previous versions of your package exist and you need to specify that your new package is compatible with them, create a file named compver with your favorite text editor.
    List the versions with which your package is compatible, using this format:
    string string . . .
    string
    Is identical to the value assigned to the VERSION parameter in the pkginfo file, for each compatible package.
  3. Save your changes and quit the editor.
  4. If your package depends on the existence of other packages, other packages depend on the existence of your package, or your package is incompatible with another package, create a file named depend with your favorite text editor.
    Add an entry for each dependency, using this format:
    type pkg-abbrev pkg-name
        (arch) version
        (arch) version . . .
    type
    Defines the dependency type. Must be one of the following characters: P (prerequisite package), I (incompatible package), or R (reverse dependency).
    pkg-abbrev
    Specifies the package abbreviation, such as SUNWcadap.
    pkg-name
    Specifies the full package name, such as Chip designers need CAD application software to design abc chips. Runs only on xyz hardware and is installed in the usr partition.
    (arch)
    Optional. Specifies the type of hardware on which the package runs. For example, sparc or x86. If you specify an architecture, you must use the parentheses as delimiters.
    version
    Optional. Specifies the value assigned to the VERSION parameter in the pkginfo file.
    For more information, see depend(4).
  5. Save your changes and quit the editor.
  6. Complete one of the following tasks:
  7. Build your package.
    See How to Build a Package, if needed.
Where to Go Next
After you build the package, install it to confirm that it installs correctly and verify its integrity. Chapter 4, Verifying and Transferring a Package explains how to do this and provides step-by-step instructions on how to transfer your verified package to a distribution medium.
Example—compver File
In this example, there are four versions of a package: 1.0, 1.1, 2.0, and the new package, 3.0, which is compatible with all the three previous versions. The compver file for the newest version might look like:
release 3.0
release 2.0
version 1.1
1.0
Note –
The entries do not have to be in sequential order. However, they should exactly match the definition of the VERSION parameter in each package's pkginfo file. In this example, the package designers used different formats in the first three versions.
Example—depend File
This example assumes that the sample package, SUNWcadap, requires that the SUNWcsr and SUNWcsu packages already be installed on a target system. The depend file for SUNWcadap looks like:
P SUNWcsr Core Solaris, (Root)
P SUNWcsu Core Solaris, (Usr)
Writing a Copyright Message
You need to decide whether your package should display a copyright message while it is being installed. If so, create the copyright file.
Note –
You should include a copyright file to provide legal protection for your software application. It might be a good idea to check with the legal department of your company for the exact wording of the message.
To deliver a copyright message, you must create a file named copyright. During installation, the message is displayed exactly as it appears in the file (with no formatting). See copyright(4) for more information.
Note –
Be certain that your copyright file has an entry in the prototype file. Its file type should be i (for package information file).
  2. Create a file named copyright with your favorite text editor.
    Enter the text of the copyright message exactly as you want it to appear as your package is installed.
  4. Complete one of the following tasks.
  5. Build your package.
Where to Go Next
Example—copyright File
For example, a partial copyright message might look like:
Copyright (c) 1999 Company Name
All Rights Reserved
This product is protected by copyright and distributed under
licenses restricting copying, distribution and decompilation.
Reserving Additional Space on a Target System
You need to determine whether your package needs additional disk space on the target system (space in addition to that required by the package objects). If so, create the space information file. This is different than creating empty files and directories at installation time as discussed in Defining Additional Objects to Be Created at Install Time.
While the pkgadd command ensures that there is enough disk space to install your package based on the object definitions in the pkgmap file, a package may require additional disk space beyond that needed by the objects defined in the pkgmap file. For example, your package might create a file after installation, which may contain a database, log files, or some other growing file that consumes disk space. To be sure that there is space set aside for it, you should include a space file specifying the disk space requirements. The pkgadd command checks for the additional space specified in a space file. Refer to space(4) for more information.
Note –
Be certain that your space file has an entry in the prototype file. Its file type should be i (for package information file).
  2. Create a file named space with your favorite text editor.
    Enter any additional disk space requirements needed by your package, using this format:
    pathname  blocks  inodes
    pathname
    Specifies a directory name, which may or may not be the mount point for a file system.
    blocks
    Specifies the number of 512-byte blocks that you want reserved.
    inodes
    Specifies the number of required inodes.
    For more information, see space(4).
Where to Go Next
Example—space File
This example space file specifies that 1000 512-byte blocks and 1 inode be set aside in /opt on the target system.
/opt   1000   1
Creating Installation Scripts
This section discusses optional package installation scripts. The pkgadd command automatically performs all the actions necessary to install a package using the package information files as input. You do not have to supply any package installation scripts. However, if you want to create customized installation procedures for your package, you can do so with installation scripts. Installation scripts:
There are four types of installation scripts with which you can perform customized actions:
Script Processing During Package Installation
The type of scripts you use depends on when the action of the script is needed during the installation process. As a package is installed, the pkgadd command performs the following steps:
  1. Executes the request script.
    This is the only point at which your package can solicit input from the administrator installing the package.
  2. Executes the checkinstall script.
    The checkinstall script gathers file system data and can create or alter environment variable definitions to control the subsequent installation. For more information on package environment variables, see Package Environment Variables.
  3. Executes the preinstall script.
  4. Installs package objects, for each class to be installed.
    Installation of these files occurs class by class, and class action scripts are executed accordingly. The list of classes operated on and the order in which they should be installed is initially defined with the CLASSES parameter in your pkginfo file. However, your request script or checkinstall script can change the value of the CLASSES parameter. For more information on how classes are processed during installation, see How Classes Are Processed During Installation.
    1. Creates symbolic links, devices, named pipes, and required directories.
    2. Installs the regular files (file types e, v, f), based on their class.
      The class action script is passed only regular files to install. All other package objects are created automatically from information in the pkgmap file.
    3. Creates all hard links.
  5. Executes the postinstall script.
Script Processing During Package Removal
When a package is being removed, the pkgrm command performs these steps:
  1. Executes the preremove script.
  2. Removes the package objects, for each class.
    Removal also occurs class by class. Removal scripts are processed in the reverse order of installation, based on the sequence defined in the CLASSES parameter. For more information on how classes are processed during installation, see How Classes Are Processed During Installation.
    1. Removes hard links.
    2. Removes regular files.
    3. Removes symbolic links, devices, and named pipes.
  3. Executes the postremove script.
The request script is not processed at the time of package removal. However, its output (a list of environment variables) is retained in the installed package and made available to removal scripts.
Package Environment Variables Available to Scripts
The following groups of environment variables are available to all installation scripts. Some of the environment variables can be modified by a request or checkinstall script.
Obtaining Package Information for a Script
Two commands can be used from scripts to solicit information about a package:
Exit Codes for Scripts
Each script must exit with one of the exit codes shown in the following table.
Table 3–3 Installation Script Exit Codes
Code
Meaning
0
Successful completion of script.
1
Fatal error. Installation process is terminated at this point.
2
Warning or possible error condition. Installation continues. A warning message is displayed at the time of completion.
3
The pkgadd command is cleanly halted. Only the checkinstall script returns this code.
10
System should be rebooted when installation of all selected packages is completed. (This value should be added to one of the single-digit exit codes described above.)
20
System should be rebooted immediately upon completing installation of the current package. (This value should be added to one of the single-digit exit codes described above.)
See Chapter 5, Package Creation Case Studies for examples of exit codes returned by installation scripts.
Note –
All installation scripts delivered with your package should have an entry in the prototype file. The file type should be i (for package installation script).
Writing a request Script
The request script is the only way your package can interact directly with the administrator installing it. It can be used, for example, to ask the administrator if optional pieces of a package should be installed.
The output of a request script must be a list of environment variables and their values. This list can include any of the parameters you created in the pkginfo file and the CLASSES and BASEDIR parameters. The list can also introduce environment variables that have not been defined elsewhere (although the pkginfo file should always provide default values, when practical). For more information on package environment variables, see Package Environment Variables.
When your request script assigns values to a environment variable, it must then make those values available to the pkgadd command and other package scripts.
request Script Behaviors
Design Rules for request Scripts
Note –
If it is possible that the administrators who will be installing your package will be using the JumpStartTM product, then the installation of your package must not be interactive. This implies that either you should not provide a request script with your package, or you need to communicate to the administrator that they should use the pkgask command, prior to installation, to store their responses to the request script. For more information on the pkgask command, see pkgask(1M).
  2. Create a file named request with your favorite text editor.
  3. Save your changes and quit the editor when you are done.
Where to Go Next
Example—Writing a request Script
When a request script assigns values to environment variables, it must make those values available to the pkgadd command. This example shows a request script segment that performs this task for the four environment variables CLASSES, NCMPBIN, EMACS, and NCMPMAN. (These were defined in an interactive session with the administrator earlier in the script.)
# make environment variables available to installation
# service and any other packaging script we might have
cat >$1 <<!
CLASSES=$CLASSES
NCMPBIN=$NCMPBI
EMACS=$EMACS
NCMPMAN=$NCMPMAN
Gathering Data With the checkinstall Script
The checkinstall script is executed shortly after the optional request script. It runs as the user install, if such a user exists, or the user nobody. The checkinstall script does not have the authority to change file system data; it is strictly a data gatherer. However, based on the information it gathers, it can create or modify environment variables in order to control the course of the resulting installation. It is also capable of cleanly halting the installation process.
The checkinstall script is intended to perform basic checks on a file system that would not be normal for the pkgadd command. For example, it can be used to check ahead to determine if any files from the current package are going to overwrite existing files, or manage general software dependencies (the depend file only manages package-level dependencies).
Unlike the request script, the checkinstall script is executed whether or not a response file is provided; and, its presence does not brand the package as “interactive.” This means that the checkinstall script can be used in situations where a request script is forbidden or administrative interaction is not practical.
Note –
The checkinstall script is available starting with the Solaris 2.5 and compatible releases.
checkinstall Script Behaviors
Design Rules for checkinstall Scripts
  2. Create a file named checkinstall with your favorite text editor.
Where to Go Next
Example—Writing a checkinstall Script
This example checkinstall script checks to see if database software needed by the SUNWcadap package is installed.
# checkinstall script for SUNWcadap
# This confirms the existence of the required specU database
# First find which database package has been installed.
pkginfo -q SUNWspcdA	# try the older one
if [ $? -ne 0 ]; then
   pkginfo -q SUNWspcdB	# now the latest
	  if [ $? -ne 0 ]; then	# oops
		    echo "No database package can be found. Please install the"
		    echo "SpecU database package and try this installation again."
		    exit 3		# Suspend
	  else
		    DBBASE="`pkgparam SUNWsbcdB BASEDIR`/db"	# new DB software
	  fi
else
	  DBBASE="`pkgparam SUNWspcdA BASEDIR`/db"	# old DB software
fi
# Now look for the database file we will need for this installation
if [ $DBBASE/specUlatte ]; then
	  exit 0		# all OK
else
	  echo "No database file can be found. Please create the database"
	  echo "using your installed specU software and try this"
	  echo "installation again."
	  exit 3		# Suspend
fi
Writing Procedure Scripts
The procedure scripts provide a set of instructions to be performed at particular points in package installation or removal. The four procedure scripts must be named one of the predefined names, depending on when the instructions are to be executed, and are executed without arguments.
Procedure Script Behaviors
Procedure scripts are executed as uid=root and gid=other.
Design Rules for Procedure Scripts
  2. Create one or more procedure scripts with your favorite text editor.
    A procedure script must be named one of the predefined names: preinstall, postinstall, preremove, or postremove.
Where to Go Next
Writing Class Action Scripts
Defining Object Classes
Object classes allow a series of actions to be performed on a group of package objects at installation or removal. You assign objects to a class in the prototype file. All package objects must be given a class, although the class of none is used by default for objects that require no special action.
The installation parameter CLASSES, defined in the pkginfo file, is a list of classes to be installed (including the none class).
Note –
Objects defined in the pkgmap file that belong to a class not listed in this parameter in the pkginfo file will not be installed.
The CLASSES list determines the order of installation. Class none is always installed first, if present, and removed last. Since directories are the fundamental support structure for all other file system objects, they should all be assigned to the none class. Exceptions can be made, but as a general rule, the none class is safest. The reason for this is to ensure that the directories are created before the objects they will contain and also to ensure that no attempt is made to delete a directory before it has been emptied.
The following list describes the system actions that occur when a class is installed. The actions are repeated once for each volume of a package as that volume is being installed.
  1. The pkgadd command creates a path name list.
    The pkgadd command creates a list of path names upon which the action script will operate. Each line of this list contains source and destination path names, separated by a space. The source path name indicates where the object to be installed resides on the installation volume and the destination path name indicates the location on the target system where the object should be installed. The contents of the list are restricted by the following criteria:
    • The list contains only path names belonging to the associated class.
    • If the attempt to create the package object fails, directories, named pipes, character devices, block devices, and symbolic links are included in the list with the source path name set to /dev/null. Normally they will be automatically created by the pkgadd command (if not already in existence) and given proper attributes (mode, owner, group) as defined in the pkgmap file.
    • Linked files where the file type is l are not included in the list under any circumstances. Hard links in the given class are created in item 4.
  2. If no class action script is provided for installation of a particular class, the path names in the generated list are copied from the volume to the appropriate target location.
  3. If there is a class action script, the script is executed.
    The class action script is invoked with standard input containing the list generated in item 1. If this is the last volume of the package, or there are no more objects in this class, the script is executed with the single argument of ENDOFCLASS.
    Note –
    Even if there are no regular files of this class anywhere in the package, the class action script will be called at least once with an empty list and the ENDOFCLASS argument.
  4. The pkgadd command performs a content and attribute audit and creates hard links.
    After successfully executing items 2 or 3, the pkgadd command audits both content and attribute information for the list of path names. The pkgadd command creates the links associated with the class automatically. Detected attribute inconsistencies are corrected for all path names in the generated list.
How Classes Are Processed During Removal
Objects are removed class by class. Classes that exist for a package but that are not listed in the CLASSES parameter are removed first (for example, an object installed with the installf command). Classes listed in the CLASSES parameter are removed in reverse order. The none class is always removed last. The following list describes the system actions that occur when a class is removed:
  1. The pkgrm command creates a path name list.
    The pkgrm command creates a list of installed path names that belong to the indicated class. Path names referenced by another package are excluded from the list unless their file type is e (meaning the file should be edited upon installation or removal).
    If the package being removed modified any files of type e during installation, it should remove just the lines it added. Do not delete a non-empty editable file; just remove the lines the package added.
  2. If there is no class action script, the path names are deleted.
    If your package has no removal class action script for the class, all the path names in the list generated by the pkgrm command are deleted.
    Note –
    Files with a file type of e (editable), which are not assigned to a class and an associated class action script, will be removed at this point, even if the path name is shared with other packages.
    The pkgrm command invokes the class action script with standard input for the script containing the list generated in item 1.
  4. The pkgrm command performs an audit.
    After successfully executing the class action script, the pkgrm command removes knowledge of the path names from the package database unless a path name is referenced by another package.
The Class Action Script
The class action script defines a set of actions to be executed during installation or removal of a package. The actions are performed on a group of path names based on their class definition. (See Chapter 5, Package Creation Case Studies for examples of class action scripts.)
The name of a class action script is based on the class on which it should operate and whether those operations should occur during package installation or removal. The two name formats are as follows:
Name Format
Description
i.class
Operates on path names in the indicated class during package installation.
r.class
Operates on path names in the indicated class during package removal.
For example, the name of the installation script for a class named manpage would be i.manpage and the removal script would be named r.manpage.
Note –
This file name format is not used for files belonging to the sed, awk, or build system classes. For more information on these special classes, see The Special System Classes.
Class Action Script Behaviors
Design Rules for Class Action Scripts
The system provides four special classes. They are:
If there are several files in a package that require special processing that can be fully defined through sed, awk, or sh commands, installation will be faster by using the system classes rather than multiple classes and their corresponding class action scripts.
The sed Class Script
The sed class provides a method to modify an existing object on the target system. The sed class action script executes automatically at installation if a file belonging to class sed exists. The name of the sed class action script should be the same as the name of the file on which the instructions will be executed.
A sed class action script delivers sed instructions in the format shown in the figure below.
Figure 3–1 Format of a sed Class Action Script
# comment, which may appear on any line in the file
!install
# sed(1) instructions which will be invoked during
# installation of the object
[address [,address]] function [arguments]
!remove
# sed(1) instructions to be invoked during the removal process
Two commands indicate when instructions should be executed. The sed instructions that follow the !install command are executed during package installation and those that follow the !remove command are executed during package removal. It does not matter which order these commands are used in the file.
For more information on sed instructions, see sed(1). For examples of sed class action scripts, see Chapter 5, Package Creation Case Studies.
The awk Class Script
The awk class provides a method to modify an existing object on the target system. Modifications are delivered as awk instructions in an awk class action script.
The awk class action script is executed automatically at installation if a file belonging to class awk exists. Such a file contains instructions for the awk class script in the format shown in the figure below.
Figure 3–2 Format of an awk Class Action Script
!install
# awk(1) program to install changes
 . . . (awk program)
!remove
# awk1(1) program to remove changes
 . . . (awk program)
Two commands indicate when instructions should be executed. The awk instructions that follow the !install command are executed during package installation, and those that follow the !remove command are executed during package removal. It does not matter in which order these commands are used in the file.
The name of the awk class action script should be the same as the name of the file on which the instructions will be executed.
The file to be modified is used as input to awk and the output of the script ultimately replaces the original object. Environment variables may not be passed to the awk command with this syntax.
For more information on awk instructions, see awk(1).
The build Class Script
The build class creates or modifies a package object file by executing Bourne shell instructions. These instructions are delivered as the package object, which runs automatically at installation if it belongs to the build class.
The name of the build class action script should be the same as the name of the file on which the instructions will be executed, and must be executable by the sh command. The script's output becomes the new version of the file as it is built or modified. If the script produces no output, the file will not be created or modified. Therefore, the script can modify or create the file itself.
For example, if a package delivers a default file, /etc/randomtable, and if the file does not already exist on the target system, the prototype file entry might be:
e build /etc/randomtable ? ? ?
and the package object, /etc/randomtable, might look like this:
!install
# randomtable builder
if [ -f $PKG_INSTALL_ROOT/etc/randomtable ]; then
		echo "/etc/randomtable is already in place.";
	    else
		echo "# /etc/randomtable" > $PKG_INSTALL_ROOT/etc/randomtable
		echo "1121554	# first random number" >> $PKG_INSTALL_ROOT/etc/randomtable
fi
!remove
# randomtable deconstructor
		# the file can be removed if it's unchanged
		if [ egrep "first random number" $PKG_INSTALL_ROOT/etc/randomtable ]; then
			rm $PKG_INSTALL_ROOT/etc/randomtable;
		fi
fi
See Chapter 5, Package Creation Case Studies for another example using the build class.
The preserve Class Script
The preserve class preserves a package object file by determining whether or not an existing file should be overwritten when the package is installed. Two possible scenarios when using a preserve class script are:
Both scenario outcomes are considered successful by the preserve script. A failure occurs only, when in the second scenario, the file is unable to be copied to the target directory.
Starting with the Solaris 7 release, the i.preserve script and a copy of this script, i.CONFIG.prsv, can be found in the /usr/sadm/install/scripts directory with the other class action scripts.
Modify the script to include the filename or filenames you would like to preserve.
  2. Assign the package objects in the prototype file the desired class names. For example, assigning objects to an application and manpage class would look like:
    f manpage /usr/share/man/manl/myappl.1l
    f application /usr/bin/myappl
  3. Modify the CLASSES parameter in the pkginfo file to contain the class names you want to use in your package. For example, entries for the application and manpage classes would look like:
    CLASSES=manpage application none
    Note –
    The none class is always installed first and removed last, regardless of where it appears in the definition of the CLASSES parameter.
  4. If you are a creating class action script for a file belonging to the sed, awk, or build class, make the directory containing the package object your current working directory.
  5. Create the class action scripts or package objects (for files belonging to the sed, awk, or build class). An installation script for a class named application would be named i.application and a removal script would be named r.application.
    Remember, when a file is part of a class that has a class action script, the script must install the file. The pkgadd command does not install files for which a class action script exists, although it does verify the installation. And, if you define a class but do not deliver a class action script, the only action taken for that class is to copy components from the installation medium to the target system (the default pkgadd behavior).
  6. Complete one of the following tasks.
Where to Go Next
Creating Signed Packages
The process of creating signed packages involves a number of steps and requires some comprehension of new concepts and terminology. This section provides information about signed packages, its terminology, and information about certificate management. This section also provides step-by-step procedures about how to create a signed package.
Signed Packages
A signed package is a normal stream-format package that has a digital signature (PEM-encoded PKCS7 digital signature which is defined below) that verifies the following:
A signed package is identical to an unsigned package, except for the signature. A signed package is binary-compatible with an unsigned package. Therefore, a signed package can be used with older versions of the packaging tools. However, the signature is ignored in this case.
The signed packaging technology introduces some new terminology and abbreviations, which are described in the following table.
Term
Definition
ASN.1
Abstract Syntax Notation 1 - A way of expressing abstract objects. For example, ASN.1 defines a public key certificate, all of the objects that make up the certificate, and the order in which the objects are collected. However, ASN.1 does not specify how the objects are serialized for storage or transmission.
X.509
ITU-T Recommendation X.509 - Specifies the widely-adopted X.509 public key certificate syntax.
DER
Distinguished Encoding Rules - A binary representation of an ASN.1 object and defines how an ASN.1 object is serialized for storage or transmission in computing environments.
PEM
Privacy Enhanced Message - A way to encode a file (in DER or another binary format) using base 64 encoding and some optional headers. PEM was initially used for encoding MIME-type email messages. PEM is also used extensively for encoding certificates and private keys into a file that exists on a file system or in an email message.
PKCS7
Public Key Cryptography Standard #7 - This standard describes a general syntax for data that may have cryptography applied to it, such as digital signatures and digital envelopes. A signed package contains an embedded PKCS7 signature. This signature contains at a minimum the encrypted digest of the package, along with the signer's X.509 public key certificate. The signed package can also contain chain certificates. Chain certificates can be used when forming a chain of trust from the signer's certificate to a locally-stored trusted certificate.
PKCS12
Public Key Cryptography Standard #12 - This standard describes a syntax for storing cryptographic objects on disk. The package keystore is maintained in this format.
Package keystore
A repository of certificates and keys that can be queried by the package tools.
Certificate Management
Before creating a signed package, you must have a package keystore. This package keystore contains certificates in the form of objects. Two types of objects exist in a package keystore:
Trusted certificate
A trusted certificate contains a single public key certificate that belongs to another entity. The trusted certificate is named as such because the keystore owner trusts that the public key in the certificate indeed belongs to the identity indicated by the “subject” (owner) of the certificate. The issuer of the certificate vouches for this trust by signing the certificate.
Trusted certficates are used when verifying signatures and when initiating a connection to a secure (SSL) server.
User key
A user key holds sensitive cryptographic key information. This information is stored in a protected format to prevent unauthorized access. A user key consists of both the user's private key and the public key certificate that corresponds to the private key.
User keys are used when creating a signed package.
By default, the package keystore is stored in the /var/sadm/security directory. Individual users can also have their own keystore stored by default in the $HOME/.pkg/security directory.
On disk, a package keystore can be in two formats: a multiple-file format and a single-file format. A multiple-file format stores its objects in multiple files. Each type of object is stored in a separate file. All of these files must be encrypted using the same passphrase. A single-file keystore stores all of its objects in a single file on the file system.
The primary utility used to manage the certificates and the package keystore is the pkgadm command. The following subsections describe the more common tasks used for managing the package keystore.
Adding Trusted Certificates to the Package Keystore
A trusted certficate can be added to the package keystore using the pkgadm command. The certificate can be in PEM or DER format. For example:
$ pkgadm addcert -t /tmp/mytrustedcert.pem
In this example, the PEM format certificate called mytrustedcert.pem is added to the package keystore.
Adding a User Certificate and Private Key to the Package Keystore
The pkgadm command does not generate user certificates or private keys. User certificates and private keys are normally obtained from a Certificate Authority, such as Verisign. Or, they are generated locally as a self-signed certificate. Once the key and certificate are obtained, they can be imported into the package keystore using the pkgadm command. For example:
pkgadm addcert -n myname -e /tmp/myprivkey.pem /tmp/mypubcert.pem
In this example, the following options are used:
-n myname
Identifies the entity (myname) in the package keystore on which you wish to operate. The myname entity becomes the alias under which the objects are stored.
Specifies the file that contains the private key. In this case, the file is myprivkey.pem, which is located in the /tmp directory.
/tmp/mypubcert.pem
Specifies the PEM format certificate file called mypubcert.pem.
Verifying the Contents in the Package Keystore
The pkgadm command is also used to view the contents of the package keystore. For example:
$ pkgadm listcert
This command displays the trusted certificates and private keys in the package keystore.
Deleting Trusted Certificates and Private Keys From the Package Keystore
The pkgadm command can be used to delete trusted certificates and private keys from the package keystore.
When you delete user certificates, the alias of the certificate/key pair must be specified. For example:
$ pkgadm removecert -n myname
The alias of the certificate is the common name of the certificate, which can be identified using the pkgadm listcert command. For example, this command deletes a trusted certificate entitled Trusted CA Cert 1:
$ pkgadm removecert -n "Trusted CA Cert 1"
Note –
If you have both a trusted certificate and a user certificate stored using the same alias, they are both deleted when you specify the -n option.
Signed Packages Creation
The process of creating signed packages involves three basic steps:
  1. Creating an unsigned, directory-format package.
  2. Importing the signing certificate, CA certificates, and private key into the package keystore.
  3. Signing the package from Step 1 with the certificates from Step 2.
Note –
The packaging tools do not create certificates. These certificates must be obtained from a Certificate Authority, such as Verisign or Thawte.
Each step for creating signed packages is described in the following procedures.
How to Create an Unsigned, Directory-Format Package
The procedure for creating an unsigned, directory-format package is the same as the procedure for creating a normal package, as previously described in this manual. The following procedure describes the process of creating this unsigned, directory-format package. If you need more information, refer to the previous sections about building packages.
  1. Create the pkginfo file.
    The pkginfo file should have the following basic content:
    PKG=SUNWfoo
    BASEDIR=/
    NAME=My Test Package
    ARCH=sparc
    VERSION=1.0.0
    CATEGORY=application
  2. Create the prototype file.
    The prototye file should have the following basic content:
    $cat prototype
    i pkginfo
    d none usr 0755 root sys
    d none usr/bin 0755 root bin
    f none usr/bin/myapp=/tmp/myroot/usr/bin/myapp 0644 root bin
  3. List the contents of the object source directory.
    For example:
    $ ls -lR /tmp/myroot
    The output would appear similar to the following:
    /tmp/myroot:
    total 16
    drwxr-xr-x   3 abc      other        177 Jun  2 16:19 usr
    /tmp/myroot/usr:
    total 16
    drwxr-xr-x   2 abc      other        179 Jun  2 16:19 bin
    /tmp/myroot/usr/bin:
    total 16
    -rw-------   1 abc      other       1024 Jun  2 16:19 myapp
  4. Create the unsigned package.
    pkgmk -d `pwd`
    ## Building pkgmap from package prototype file.
    ## Processing pkginfo file.
    WARNING: parameter <PSTAMP> set to "syrinx20030605115507"
    WARNING: parameter <CLASSES> set to "none"
    ## Attempting to volumize 3 entries in pkgmap.
    part  1 -- 84 blocks, 7 entries
    ## Packaging one part.
    /tmp/SUNWfoo/pkgmap
    /tmp/SUNWfoo/pkginfo
    /tmp/SUNWfoo/reloc/usr/bin/myapp
    ## Validating control scripts.
    ## Packaging complete.
    The package now exists in the current directory.
How to Import the Certificates Into the Package Keystore
The certificate and private key to be imported must exist as a PEM- or DER-encoded X.509 certificate and private key. In addition, any intermediate or “chain” certificates linking your signing certificate to the Certificate Authority certificate must be imported into the package keystore before a package can be signed.
Note –
Each Certificate Authority can issue certificates in various formats. To extract the certificates and private key out of the PKCS12 file and into a PEM-encoded X.509 file (suitable for importing into the package keystore), use a freeware conversion utility such as OpenSSL.
If your private key is encrypted (which should usually be the case), you are prompted for the passphrase. Also, you are prompted for a password to protect the resulting package keystore. You can optionally not supply any password, but doing so results in an unencrypted package keystore.
The following procedure describes how to import the certificates using the pkgadm command once the certificate is in the proper format.
  1. Import all the Certificate Authority certificates found in your PEM- or DER-encoded X.509 certificate file.
    For example, to import all the Certificate Authority certificates found in the file ca.pem, you would type the following:
    $ pkgadm addcert -k ~/mykeystore -ty ca.pem
    Trusting certificate <VeriSign Class 1 CA Individual \
    Subscriber-Persona Not Validated>
    Trusting certificate </C=US/O=VeriSign, Inc./OU=Class 1 Public \
    Primary Certification Authority
    Type a Keystore protection Password.
    Press ENTER for no protection password (not recommended):
    For Verification: Type a Keystore protection Password.
    Certificate(s) from <ca.pem> are now trusted
    In order to import your signing key into the package keystore, you must supply an alias that is used later when signing the package. This alias can also be used if you want to delete the key from the package keystore.
    For example, to import your signing key from the file sign.pem, you would type the following:
    $ pkgadm addcert -k ~/mykeystore -n mycert sign.pem
    Enter PEM passphrase:
    Enter Keystore Password:
    Successfully added Certificate <sign.pem> with alias <mycert>
  2. Verify that the certificates are in the package keystore.
    For example, to view the certificates in the keystore created in the previous step, you would type the following:
    $ pkgadm listcert -k ~/mykeystore
How to Sign the Package
Once the certificates are imported into the package keystore, you can now sign the package. The actual signing of the package is done using the pkgtrans command.
  1. Sign the package using the pkgtrans command. Supply the location of the unsigned package and the alias of the key to sign the package.
    For example, using the examples from the previous procedures, you would type the following to create a signed package called SUNWfoo.signed:
    $ pkgtrans -g -k ~/mykeystore -n mycert . ./SUNWfoo.signed SUNWfoo
    The output of this command would appear similar to the following:
    Retrieving signing certificates from keystore </home/user/mykeystore>
    Enter keystore password:
    Generating digital signature for signer <Test User>
    Transferring <SUNWfoot> package instance
    The signed package is created in the file SUNWfoo.signed and is in the package-stream format. This signed package is suitable for copying to a web site and being installed using the pkgadd command and a URL.
