Application Packaging Developer's Guide
Design Rules for request Scripts
Note –
If it is possible that the administrators who will be installing your package will be using the JumpStartTM product, then the installation of your package must not be interactive. This implies that either you should not provide a request script with your package, or you need to communicate to the administrator that they should use the pkgask command, prior to installation, to store their responses to the request script. For more information on the pkgask command, see pkgask(1M).
