Application Packaging Developer's Guide
Creating Information Files and Installation Scripts Task Map
The table below lists and describes the optional features you can build into a package.
Table 3–1 Creating Information Files and Installation Scripts Task Map
For Instructions, Go To ...
1. Create Information Files
Define Package Dependencies
A definition of package dependencies allows you to specify whether your package is compatible with previous versions, dependent on other packages, or whether other packages are dependent on yours.
How to Define Package Dependencies
Provide a Copyright Message
A copyright file provides legal protection for your software application.
How to Write a Copyright Message
Create Additional Space on the Target System.
A space file sets aside blocks on the target system, which enables you to create files during installation that are not defined in the pkgmap file.
How to Reserve Additional Space on a Target System
2. Create Installation Scripts
Obtain Information From the Installer
A request script enables you to obtain information from the person installing your package.
How to Write a request Script
Gather File System Data Needed For Installation
A checkinstall script enables you to perform an analysis of the target system and set up the correct environment for, or cleanly halt, the installation.
How to Gather File System Data
Write Procedure Scripts
Enables you to provide customized installation instructions during specific phases of the installation or removal process.
How to Write Procedure Scripts
Write Class Action Scripts
Enables you to specify a set of instructions to be executed during package installation and removal on specific groups of package objects.
How to Write Class Action Scripts
