Application Packaging Developer's Guide
How to Install a Package on a Standalone or Server
  1. Build your package.
    See Building a Package, if needed.
  2. Log in to the system as superuser.
  3. Add the software package to the system.
    # pkgadd -d device-name [pkg-abbrev...]
    -d device-name
    Specifies the location of the package. Note that device-name can be a full directory path name or the identifiers for a tape, floppy disk, or removable disk.
    Is the name of one or more packages (separated by spaces) to be added. If omitted, pkgadd installs all available packages.
Where to Go Next
If you are ready to go to the next task, see How to Verify the Integrity of Your Package.
Example—Installing Packages on Standalones and Servers
To install a software package named pkgA from a tape device named /dev/rmt/0, you would enter the following command:
# pkgadd -d /dev/rmt/0 pkgA
You can also install multiple packages at the same time, as long as you separate package names with a space, as follows:
# pkgadd -d /dev/rmt/0 pkgA pkgB pkgC
If you do not name the device on which the package resides, the command checks the default spool directory (/var/spool/pkg). If the package is not there, the installation fails.
